Today is my first day in the Arduino world, and I felt excited about the idea, confused about some information, and overwhelmed about everything I want to learn and do.
It took me a while to make sense of what the Arduino IDE and language is, but after jumping through several links I think I finally have a better understanding. I also noticed many people using the wrong terms, like referring to Arduino language as Processing language, so as a newcomer it got very confusing. If I had seen the following information in the same place, I would've understood the overall picture in seconds. So I hope all newcomers get to see the following explanation.
Explanations
Chart:
Analogy:
Processing had two kids: Wiring was the first one, and Arduino learned a lot from his older bro.
Text:
The Arduino IDE is written in Java and based mainly on the Processing IDE (used to write in Processing language which uses Java-like syntax).
The Arduino IDE installation comes with the RXTX library (a serial and parallel communications library made for use in Java), because the serial monitor needs to communicate to the serial port via the RXTX library.
The Arduino language is based on Wiring(a simplified version of C/C++). So this means the Arduino language is written using C++like syntax, and it communicates to the serial port via the Wiring library.
Comments
At first, the comparison between Processing and Arduino http://arduino.cc/en/Reference/Comparison made me think that the Arduino IDE also supports Processing language. Which is not the case, correct? So the purpose of that comparison should be clearly stated.
I read that Processing, Wiring, and Arduino IDE use the file extension .pde (processing development environment). I find this kind of confusing because I assume that code written in Processing won't work in Wiring, Arduino, and vice versa. It would be nice to have .pde, .wde, and .ade just for clarification.
Question
I would like to use Eclipse to write programs in Java and communicate with an Arduino board via the RXTX library that comes with the Arduino IDE. Now, I see the Arduino IDE has an upload button.
How can I upload stuff to the Arduino Board using Java Eclipse?
Thanks for reading.
