Making Serial.print() to echo back
I uploaded the code below to Arduino and the purpose of this is to echo back what has just been sent to it through Serial.
Problem is: it is not echoing back.
Do you guys know why?
Thanks
P.S: I'm using the Serial Monitor provided by the Arduino IDE.
  if (Serial.available()) {
    Serial.print((char) Serial.read());
    delay(10);
What happens when you hit 'send?
try using a var inbetween
  if (Serial.available() > 0)
    char c = Serial.read();
    Serial.print( c );
  delay(10);
@AWOL It just sends but returns nothing. Doesn't even show up what I've just sent.
@robtillaart Tried that before. Still doesn't work.
(deleted)
Does this work?
  Serial.print("Hello world");
  delay(10);
Yes it does.
Seems like something with the Serial.available() condition.
@spycatcher2k Yes!
char inByte;  // incoming serial byte
  Serial.begin(9600);          // serial communication baud rate
// while loop begins here, continous loop:
  if (Serial.available()) {    // check for incoming data --> if available
  inByte = Serial.read();      // store incoming data
  Serial.print(inByte);        // echo back the data
This code should get you going....
Can also be a hardware failure,
change cable e.g. with your printers cable
robtillaart:
Either I caught rob trying to be a hardware guy (I have an impression that he is software guy) or the OP didn't even upload the sketch to the arduino. :grin:
If I assume the sketch was loaded to arduino, then the hardware was able to do both read and write over serial.
Yes, you caught me :wink: indeed software guy by profession and hobby, but learned a lot about HW here
and If the read failed during upload ... the sketch wasn't uploaded and it would not echo back .....
I suppose I should try this scenario, disconnect arduino tx and see what error message (if at all) pops up during a sketch upload. I assumed there would be an error I don't actually have any experience.
