Hi, everyone who love arduino.
Im working on making sound by using ultrasonic sensor. I use 3 button and 1 ultrasonic sensor. By touching a button, it makes sound. What I
m trying to do is adding ultrasonic sensor. By catching jumping motion, Id like to make sound. There is one sound file that tells "please jump 4 times". After the file worked, I
d like to ultrasonic sensor catch the jumping motion of the human who holding it. Therefore, Id like to make sound. Attached is my connection between the sensor and arduino. I
m using arduino duemilanove and audio shield. I tried many time to make it, but I couldn`t do that.
This is my code. i,j, and k are buttons. Val is ultrasonic sensor.
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include "WaveUtil.h"
#include "WaveHC.h"
SdReader card; // This object holds the information for the card
FatVolume vol; // This holds the information for the partition on the card
FatReader root; // This holds the information for the filesystem on the card
FatReader f; // This holds the information for the file we're play
WaveHC wave; // This is the only wave (audio) object, since we will only play one at a time
#define DEBOUNCE 100 // button debouncer
int i=0;// pin0
int j=0;//pin 1
int k=0;//pin 2
int Val=0; //sensor
// this handy function will return the number of bytes currently free in RAM, great for debugging!
int freeRam(void)
extern int __bss_end;
extern int *__brkval;
int free_memory;
if((int)__brkval == 0) {
free_memory = ((int)&free_memory) - ((int)&__bss_end);
else {
free_memory = ((int)&free_memory) - ((int)__brkval);
return free_memory;
void sdErrorCheck(void)
if (!card.errorCode()) return;
putstring("\n\rSD I/O error: ");
Serial.print(card.errorCode(), HEX);
putstring(", ");
Serial.println(card.errorData(), HEX);
while(1);
// set up serial port
putstring_nl("WaveHC with 6 buttons");
putstring("Free RAM: "); // This can help with debugging, running out of RAM is bad
Serial.println(freeRam()); // if this is under 150 bytes it may spell trouble!
// Set the output pins for the DAC control. This pins are defined in the library
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
// pin13 LED
pinMode(13, OUTPUT);
// enable pull-up resistors on switch pins (analog inputs)
digitalWrite(14, HIGH);
digitalWrite(15, HIGH);
digitalWrite(16, HIGH);
digitalWrite(17, HIGH);
digitalWrite(18, HIGH);
digitalWrite(19, HIGH);
if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
/*if (!card.init()) { //play with 8 MHz spi (default faster!)
putstring_nl("Card init. failed!"); // Something went wrong, lets print out why
sdErrorCheck();
while(1);*/ // then 'halt' - do nothing!
// enable optimize read - some cards may timeout. Disable if you're having problems
card.partialBlockRead(true);
// Now we will look for a FAT partition!
uint8_t part;
for (part = 0; part < 5; part++) { // we have up to 5 slots to look in
if (vol.init(card, part))
break; // we found one, lets bail
if (part == 5) { // if we ended up not finding one :(
putstring_nl("No valid FAT partition!");
sdErrorCheck(); // Something went wrong, lets print out why
while(1); // then 'halt' - do nothing!
// Lets tell the user about what we found
putstring("Using partition ");
Serial.print(part, DEC);
putstring(", type is FAT");
Serial.println(vol.fatType(),DEC); // FAT16 or FAT32?
// Try to open the root directory
if (!root.openRoot(vol)) {
putstring_nl("Can't open root dir!"); // Something went wrong,
// Whew! We got past the tough parts.
putstring_nl("Ready!");
//putstring("."); // uncomment this to see if the loop isnt running
switch (check_switches()) {
case 1:// when any button was pressed
if (i==0){//if it is the 1st press by the user
i++;
j++;
k++;
playfile("I.WAV");// intro story
if(i==1){
i++;
playfile("S11.WAV");
if(i==2){
i++;
playfile("S12.WAV");
if(i==3){
i++;
playfile("S13.WAV");
if (i==4){
i++;
playfile("S14.WAV");
if (i==5){
i++;
playfile("S15.WAV");
if (i==6){
i=1;
playfile("I.WAV");
case 2: //pin 1
if (j==0){ //pin 1
j++;
i++;
k++;
playfile("I.WAV");
if(j==1){
playfile("S21.WAV");
Val = analogRead(3);
if(Val<25){
playfile("race001.wav");
Serial.println(Val);
j++;
if(j==2){
j++;
playfile("S22.WAV");
if(j==3){
j++;
playfile("S23.WAV");
if (j==4){
j++;
playfile("S24.WAV");
if (j==5){
j++;
playfile("S25.WAV");
if (j==6){
j++;
playfile("S26.WAV");
if (j==7){
j=1;
playfile("I.WAV");
case 3: //pin 2
if (k==0){
k++;
i++;
j++;
playfile("I.WAV");
if(k==1){
k++;
playfile("S31.WAV");
if(k==2){
k++;
playfile("S32.WAV");
if(k==3){
k++;
playfile("S33.WAV");
if (k==4){
k++;
playfile("S34.WAV");
if (k==5){
k++;
playfile("S35.WAV");
if (k==6){
k++;
playfile("S36.WAV");
if (k==7){
k=1;
playfile("I.WAV");
byte check_switches()
static byte previous[6];
static long time[6];
byte reading;
byte pressed;
byte index;
pressed = 0;
for (byte index = 0; index < 6; ++index) {
reading = digitalRead(14 + index);
if (reading == LOW && previous[index] == HIGH && millis() - time[index] > DEBOUNCE)
// switch pressed
time[index] = millis();
pressed = index + 1;
previous[index] = reading;
// return switch number (1 - 6)
return (pressed);
// Plays a full file from beginning to end with no pause.
void playcomplete(char *name) {
// call our helper to find and play this name
playfile(name);
while (wave.isplaying) {
// do nothing while its playing
// now its done playing
void playfile(char *name) {
// see if the wave object is currently doing something
if (wave.isplaying) {// already playing something, so stop it!
wave.stop();// stop it
// look in the root directory and open the file
if (!f.open(root, name)) {
putstring("Couldn't open file "); Serial.print(name); return;
// OK read the file and turn it into a wave object
if (!wave.create(f)) {
putstring_nl("Not a valid WAV"); return;
wave.play();
// ok time to play! start playback
What Ive got is two things. First thing is makind sound whatever the value from ultrasonic sensor. Second thing is skipping S21, and race001 file. I
m working on it over 4months, but it still makes me frastrated. Could help me...
