Making Steppers Move Much Smoother In A Large Program
Hi Guys!
I'm a student currently working on a Rotary Moulding Machine project. (See the below video and Frit Wiring for reference!)
https://drive.google.com/file/d/1EsFc_DDtBo-3YVjJ3uttKNI1gbPCGulW/view?usp=sharing
I have a TFT screen, buttons and two Easy Drivers wired up with Nema 17 motors (See Frit Wiring - note the input was changed to buttons instead of a rotary encoder). With all of this said, I have created a program that has a menu system that allows the user to select the Moulding Ratio, speed and Time. The program then goes ahead and mould the part - with some extra features such as an emergency switch etc.
My big question is, when you look at the video, there is a slight PAUSE or JUTTER each second that makes the motion juttery and not flow as well as I would like. I have been working on different methods to reduce the amount of lines the processor has to run while it is moulding (checks for the end time, so when it reaches a certain time it then stops moulding) however, upon refining this, the biggest issue is the TFT refresh (updating the time on the screen every second).
My question is, is there a way to reduce this jutter? I can just take out the TFT statement, however, this is an important part as it showcases how long is left. Is there another way?
I have attached the entire CODE however, the part I am focused on, is in the Rotary class and is the Update/UpdateHandler methods - I attempted to add it as a snippet but it was flagged as being too large! :frowning: sorrry
I understand this could be quite confusing as I am yet to go through and refine it (take out all the debug aspects) so please bear with me! If you do need any additional information, please feel free to drop a comment and I will happily let you know! Thank you kindly!
Best regards,
Jack Daly
Vertic_OS_V2.zip (14 KB)
To save you having to download the whole program, here is the ROTARY class. The Rotary.UpdateHandler runs every loop when the user presses GO in the menu to begin rotary moulding. This then manager the emergency stop, timing and of course moving the steppers!
void Rotary::update()
  for (int x = 0; x < 1000; x++) //Loop the forward stepping enough times for motion to be visible
    for (int i = 0; i < OuterRatio; i++)
    { // ratio is (outer : inner) or 1 to 1 + ratio so to get a 1:4 the for loop would be 5
      StepOuterCore(MouldSpeed); // Calculates Inner speed based on core ratio
    for (int i = 0; i < (InnerRatio + 1); i++)
      StepInnerCore((MouldSpeed * OuterRatio) / (InnerRatio + 1)); // Calculates Inner speed based on core ratio
int Rotary::StepInnerCore(int Delay)
  digitalWrite(stp, HIGH);
  delayMicroseconds(Delay);
  digitalWrite(stp, LOW);
int Rotary::StepOuterCore(int Delay)
  digitalWrite(sstp, HIGH);
  digitalWrite(sstp, LOW);
void Rotary::initialize()
  Tft.fillScreen(0x0000);
  MouldTime = EEPROM.read(MouldTimeAddress);
  //USER pressed GO to start moulding - RUN ONCE
  StartTime = millis(); // StartTime
  EndTime = StartTime + (MouldTime * 60000); // convert minutes to miliseconds. Calculate the end time.
  Serial.println("");
  Serial.print("Start Time Set: ");
  Serial.println(StartTime);
  Serial.print("End Time Set: ");
  Serial.println(EndTime);
  Tft_drawCenteredString("Begin", 16, 4, WHITE);
  Tft_drawCenteredString("Press EMERGENCY to stop", 50, 1, WHITE);
  //set change
  ScreenChange = 1;
  //Set FLAG to start moulding
  Moulding = true;
void Rotary::UpdateHandler()
  Serial.println("MOULDING");
  //Get current time this LOOP
  CurrentTime = millis();
  //Calculate END TIME----------------------------------------------------------
  if ( CurrentTime > EndTime and state == false) {
    //MouldTime is OVER
    if (Moulding == true) {
    Moulding = false;
    Tft_drawCenteredString("FINISH", 16, 4, WHITE);
    Tft_drawCenteredString("Take your mould out", 50, 1, WHITE);
    Tft_drawCenteredString("Press A to Exit", 60, 1, WHITE);
    if (controller.AButtonPressed) {
      Reset();
  //UPDATE Rotary Position-----------------------------------------------------
  if (Moulding) {
    //Display TIME-----------------------------------------------------------
    TimeLeft = EndTime - CurrentTime; // in miliseconds
    TimeLeftMinutes = (TimeLeft / 1000) / 60; // convert to minutes
    TimeLeftSeconds = (TimeLeft / 1000) - (int(TimeLeftMinutes) * 60); // convert to TOTAL seconds
        Serial.println(CurrentTime);
        Serial.println(TimeLeft);
        Serial.println(TimeLeftSeconds);
    Serial.println(TimeLeftMinutes);
    Serial.println("");
    Serial.println("");
    if (state == false and (millis() - LastPrint) > 1000) {//if no emergency switch pressed and its been a second, update the time.
      TimeString = "  " + String(int(TimeLeftMinutes)) + " Min & " + String(int(TimeLeftSeconds)) + " Sec" + "  ";
      Tft_drawCenteredString(TimeString, 80, 1, WHITE);
      LastPrint = millis();
    // no emergency skip
    if (state) { //If pressed DO NOT UPDATE
      //MEANS ITS BEEN PAUSED
      if (Flag) {    //Save current milis position
        PauseTime = millis();
        Flag = 0;
        Tft_drawCenteredString("PAUSED", 16, 4, WHITE);
        Tft_drawCenteredString("Press A to Exit", 50, 1, WHITE);
      } // do not change value, this is the time it was first paused.
      ScreenChange = 1; // The screen has changed
      //If A Button is pressed, then EXIT
        Reset();
    else {
      //RUN THIS EACH LOOP IF NO EMERGENCY
      //If not, then carry on
      if (ScreenChange) {//screen changed therefore update
        ScreenChange = 0; // reset back
        // JUST come back from pause pos so update END TIME
        //End time plus current time minus pause time so add on the time we were paused
        if (Flag == 0) {
          EndTime = EndTime + (millis() - PauseTime);
        Tft_drawCenteredString("Mould", 16, 4, WHITE);
        Serial.println("TITLE UPDATED");
      //Set flag back to 1
      Flag = 1;
      update();
void Rotary::Reset() {
  Create.currentSelection = OptCreateList; // Will therefore revert back
  controller.position.y = 1;
  state = 0; // reset state
  StartTime = 0;
  EndTime = 0;
  TimeLeft = 0;
  TimeLeftSeconds = 0;
  TimeLeftMinutes = 0;
  PauseTime = 0;
  CurrentTime = 0;
Few people here will open a zip file. If your code is < 9000 lines, then post it according to the "Read this before posting a programming question". Invariably a programming problem is usually not in the snippet provided.
Also, Fritzing pictures are NOT SCHEMATICS. But I doubt if the circuit would be where the problem lies, so I won't rag on you any more about not providing a schematic.
Does the TFT refresh coincide with the jutter? If so, then put the TFT on a separate processor. Sent the TFT processor the data by serial of I2C and then your loop won't be hesitating while the TFT is updating.
You could also use a dual-core ESP32 board and a Real-Time OS, but I have used neither.
You might try a different type of display, the LCDs are inherently slow on the Arduinos especially with the I2C interface. A schematic would make this much easier to follow then the frizzy picture.
This is an inefficient way of writing to the tft
        Flag = 0;
You only need to overwrite the part with the text, not the whole screen. fillScreen is slowing you down.
Where is the code for the steppers ? Have you considered using a timer to handle their movement ?
Also, but on a different matter.TimeString = "  " + String(int(TimeLeftMinutes)) + " Min & " + String(int(TimeLeftSeconds)) + " Sec" + "  ";How have you declared TimeString ? is it a global variable ? if so, it is going to cause issues.
    //TIME VARS
    float StartTime = 0;
    float EndTime = 0;
    float TimeLeft = 0;
    float TimeLeftSeconds = 0;
    float TimeLeftMinutes = 0;
    float PauseTime = 0;
    float LastPrint;
Your millis() values should all be 'unsigned long', not 'float'.
You should not calculate 'EndTime' as an absolute time. If you do that you will get a glitch every 47-odd days when the millisecond clock rolls over (sooner if you use 'float'?). You should only compare elapsed time (currentTime - StartTime) to a time interval.
Try changing:
to
  RunTime = MouldTime * 60000UL; // convert minutes to miliseconds. Calculate the run time.
and
to
  if ( CurrentTime - StartTime > RunTime and state == false) {
Check out my tutorial on Multi-tasking in Arduino
which includes a detailed tutorial on how to make steppers move smoothly using AccelStepper library.
Having said that updating the LCD can be slow and that will probably been your main problem.
The Multi-tasking in Arduino includes a loopTimer to help you debug how slow your loop in running and which parts are actually consuming the time.
