making switch read throughout LONG if/else sequence
hey all,
I'm making two specific light blink sequences and switching between them via a switch. However I'm only using one output, not both. When I change the state of the switch my code will finish the full if/else sequence before changing to the other, I want it to change instantly instead. I'm trying to figure out what command I can use to make the code reference the switch between each flash and delay and cannot find one that works, can anybody lend some advice?
Thanks,
Chris
Get rid of the delay()s, then.
State command and blink without delay are terms to search for.
you misunderstand, I want the sequence to run with the specified lengths of HIGH and LOW. However, I want to switch to the alternative sequence as soon as I change the state of the switch. Currently it has to finish the entire first sequence before it will switch the the alternative one.
No, I don't think Paul misunderstands.
Take a look at the blink without delay example, without delay.
(Seeing some code would help clear up misunderstandings)
