Making toys dance again (Loki)
This is an Arduino project designed with fun in mind and was originally made in just one day with what was available at home.
I had a cheap dancing toy that used to sing Christmas carols, but its circuit board was damaged when the battery leaked. It was kind of cute and I didn't want to throw it away (since everything but the main circuit was fine)
Thinking of what to do, I thought of that one Halloween craft project that used an audio player to store the movement data. I then thought "Hey, I have this nifty little audio player module I have sitting around doing nothing, what if..."
Introducing Loki, the replacement circuit for most of the dancing toys that repeat simple motions.
The project is made to be expanded upon and moved around, so it can fit many types of toys.
The code is as follows:
 * Loki (Revision 1445)
 * (C) 2022 Blackbeard Softworks
 * This code relies on external hardware to be present.
 * Please refer to the wiring diagram.
 * The music must be prepared in this way:
 * - The input file must be MP3
 * - Right channel is used exclusively for motor control (meaning you can implement PWM at low frequency with amplitude modulation - from my testing, it was <20Hz)
 * - Right channel must ONLY contain motor control signal (no voice, no music, only beeps at about 1024Hz~2048Hz. DC signal doesn't work as capacitor blocks DC signal)
 * - The beeps must not taper off in volume (it causes the motor to judder, so it needs to at least sound as if it turns on and off instantly)
 * - Use the DAW or other solutions to generate the beeps on the RIGHT CHANNEL ONLY
 * - Leave the left channel alone or adjust its volume
 * (you CANNOT adjust the volume in code. It won't work. Adding a resistor for smaller speakers does work. About 51 Ohms work well, but taping over the speaker hole works too.)
 * - Right channel MUST be at 0db attenuation (meaning, it peaks and/or clips. Crank it up!)
// DFRobot's own library is used here. We could use a lightweight library, but let's keep it simple.
#include <DFRobotDFPlayerMini.h>
#include <SoftwareSerial.h>
SoftwareSerial mySoftwareSerial(10, 11);
DFRobotDFPlayerMini myDFPlayer;
void printDetail(uint8_t type, int value);
// Do not change this value.
int songIndex = 1;
// This is the number of songs on your SD card, greeting inclusive.
// Supports up to 65535, but honestly, with one button it would be a VERY big chore to go through all 65533 tracks for accessing the last track.
// Can be LESS than the actual song count, but CANNOT BE MORE than the actual song count. This causes the function to completely fail.
const int maxSongCount = 41;
// This will be the playback button
const int button = 2;
// The statusPin is used only for legacy purposes.
const int statusPin = A0;
// Do not change these values.
volatile bool stopped = false;
volatile bool state = false;
volatile bool led = false;
// This is the pin that reverses the motor when combined with the Logic Reverser circuit.
// If you want to use other pins, change this.
const int ledPin = LED_BUILTIN;
unsigned long pm = 0;
// Change this to change how frequently the motor changes the direction
// Changing this to too small of a value may cause the motor, back EMF or power supply issues.
const long interval = 1000;
  // Setup pin modes
  pinMode(button, INPUT_PULLUP);
  pinMode(statusPin, INPUT);
  pinMode(LED_BUILTIN, OUTPUT);
  mySoftwareSerial.begin(9600);
  Serial.println(F("Loki v1.4 starting up..."));
  // Delay to let DFPlayer Mini initialize
  delay(2000);
  if (!myDFPlayer.begin(mySoftwareSerial)) {
    Serial.println(F("Unable to begin:"));
    Serial.println(F("1.Please recheck the connection!"));
    Serial.println(F("2.Please insert the SD card!"));
    while (true) {
      delay(0); // Code to compatible with ESP8266 watchdog.
  Serial.println(F("DFPlayer Mini online."));
  // This value can be adjusted to let the SD card catch up, not resulting in Time Out error
  myDFPlayer.setTimeOut(1500);
  // Must be at 30. Lower volumes just don't have the gusto to push through.
  // Technically you can add another transistor stage or Darlington transistor for this, but this is the cheapest option.
  myDFPlayer.volume(30);
  // Play the first MP3 file, which must be the greeting audio
  myDFPlayer.playMp3Folder(1);
  // Small delay to prevent malfunctions
  delay(250);
  // Legacy code start
  while (digitalRead(statusPin) == LOW) {
    // Wait while the track finishes playing
  // Legacy code end
  // Set register
  EIFR = 1;
  delay(7000); // Adjust for the prompt length
  // Attach an interrupt routine to the button
  attachInterrupt(digitalPinToInterrupt(button), playbackCtrl, FALLING);
  Serial.println("Ready");
  // This part until next comment deals with the reversing of the motor.
  unsigned long cm = millis();
  if (cm - pm >= interval) {
    pm = cm;
    led = !led;
  digitalWrite(ledPin, led);
  // End of section
  if (state == true) {
    Serial.print("Attempting to play index ");
    Serial.print(songIndex);
    Serial.println(" file");
    myDFPlayer.playMp3Folder(songIndex);
    delay(50);
    while (stopped == false) {
      Serial.println("playing");
    state = false;
  if (state == false) {
    delay(50);
    if (stopped != true) {
      Serial.println("Finished, stopping");
      myDFPlayer.stop();
      stopped = true;
  if (myDFPlayer.available()) {
    printDetail(myDFPlayer.readType(), myDFPlayer.read());
// Interrupt routine
void playbackCtrl() {
  static unsigned long lit = 0;
  // We do not want to use delay() here.
  unsigned long inttime = millis();
  // Debouncing routine, as well as toggle
  if (inttime - lit > 500) {
      state = false;
      stopped = true;
      state = true;
      stopped = true;
    // Advance the song index by one
    songIndex++;
    // If we are exceeding the maximum song index or if it's below 2 (meaning, the beginning)
    // We want to set it to 2 so the greeting message doesn't play again.
    if (songIndex > maxSongCount || songIndex < 2) {
      songIndex = 2;
  lit = inttime;
// Default DFPlayer debug function
void printDetail(uint8_t type, int value) {
  switch (type) {
    case TimeOut:
      Serial.println(F("Time Out!"));
    case WrongStack:
      Serial.println(F("Stack Wrong!"));
    case DFPlayerCardInserted:
      Serial.println(F("Card Inserted!"));
    case DFPlayerCardRemoved:
      Serial.println(F("Card Removed!"));
    case DFPlayerCardOnline:
      Serial.println(F("Card Online!"));
    case DFPlayerUSBInserted:
      Serial.println("USB Inserted!");
    case DFPlayerUSBRemoved:
      Serial.println("USB Removed!");
    case DFPlayerPlayFinished:
      Serial.print(F("Number:"));
      Serial.print(value);
      Serial.println(F(" Play Finished!"));
    case DFPlayerError:
      Serial.print(F("DFPlayerError:"));
      switch (value) {
        case Busy:
          Serial.println(F("Card not found"));
        case Sleeping:
          Serial.println(F("Sleeping"));
        case SerialWrongStack:
          Serial.println(F("Get Wrong Stack"));
        case CheckSumNotMatch:
          Serial.println(F("Check Sum Not Match"));
        case FileIndexOut:
          Serial.println(F("File Index Out of Bound"));
        case FileMismatch:
          Serial.println(F("Cannot Find File"));
        case Advertise:
          Serial.println(F("In Advertise"));
        default:
    default:
The schematic is as follows:
Note: If you hear clicking noises while the music/song is playing, you need to add 1Kohm resistors on RX and TX line between DFPlayer Mini and Arduino.
You need to extend the RESET button outside of the toy, or else you will not be able to properly initialize the circuit. (I'm working on a fix)
As usual, please be careful while using lithium-ion or lithium polymer batteries. Only use protected batteries, and if possible use canister-type batteries (such as 18650 batteries with a protection circuit inside a holder) instead of pouch-type batteries, since they can be damaged easily by children or animals (if placed outside of the case) and cause injuries.
GitHub page here for example audio file and ready-to-use Arduino sketch, as well as an explanation on the parts:
