Here is my total code: (it controls two motors which work fine and two actuators with four buttons (one to actuate and one to retract for both) it is saying in the highlighted line below that it "expected primary-expression before '>' token"
not sure what it wants.
if I did something incorrectly while posting this I apologize in advance. Still learning.
/* Arduino DC Motor Control - PWM | H-Bridge | L298N
Example 02 - Arduino Robot Car Control
by Dejan Nedelkovski, www.HowToMechatronics.com
#define enA 9
#define in1 4
#define in2 5
#define enB 10
#define in3 6
#define in4 7
#define enAb 3
#define in1b 2
#define in2b 8
#define enBb 11
#define in3b 12
#define in4b 13
const int button1 = A2;
const int button2 = A3;
const int button3 = A4;
const int button4 = A5;
int buttonState1 = 0;
int buttonState2 = 0;
int buttonState3 = 0;
int buttonState4 = 0;
int motorSpeedA = 0;
int motorSpeedB = 0;
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode(enAb, OUTPUT);
pinMode(enBb, OUTPUT);
pinMode(in1b, OUTPUT);
pinMode(in2b, OUTPUT);
pinMode(in3b, OUTPUT);
pinMode(in4b, OUTPUT);
// initializing the pushbuttons as an input //
pinMode(button1, INPUT);
pinMode(button2, INPUT);
pinMode(button3, INPUT);
pinMode(button4, INPUT);
int xAxis = analogRead(A0); // Read Joysticks X-axis
int yAxis = analogRead(A1); // Read Joysticks Y-axis
// Y-axis used for forward and backward control
if (yAxis < 470) {
// Set Motor A backward
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
// Set Motor B backward
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
// Convert the declining Y-axis readings for going backward from 470 to 0 into 0 to 255 value for the PWM signal for increasing the motor speed
motorSpeedA = map(yAxis, 470, 0, 0, 255);
motorSpeedB = map(yAxis, 470, 0, 0, 255);
else if (yAxis > 550) {
// Set Motor A forward
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
// Set Motor B forward
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
// Convert the increasing Y-axis readings for going forward from 550 to 1023 into 0 to 255 value for the PWM signal for increasing the motor speed
motorSpeedA = map(yAxis, 550, 1023, 0, 255);
motorSpeedB = map(yAxis, 550, 1023, 0, 255);
// If joystick stays in middle the motors are not moving
else {
motorSpeedA = 0;
motorSpeedB = 0;
// X-axis used for left and right control
if (xAxis < 470) {
// Convert the declining X-axis readings from 470 to 0 into increasing 0 to 255 value
int xMapped = map(xAxis, 470, 0, 0, 255);
// Move to left - decrease left motor speed, increase right motor speed
motorSpeedA = motorSpeedA - xMapped;
motorSpeedB = motorSpeedB + xMapped;
// Confine the range from 0 to 255
if (motorSpeedA < 0) {
motorSpeedA = 0;
if (motorSpeedB > 255) {
motorSpeedB = 255;
if (xAxis > 550) {
// Convert the increasing X-axis readings from 550 to 1023 into 0 to 255 value
int xMapped = map(xAxis, 550, 1023, 0, 255);
// Move right - decrease right motor speed, increase left motor speed
motorSpeedA = motorSpeedA + xMapped;
motorSpeedB = motorSpeedB - xMapped;
if (motorSpeedA > 255) {
motorSpeedA = 255;
if (motorSpeedB < 0) {
motorSpeedB = 0;
// Prevent buzzing at low speeds (Adjust according to your motors. My motors couldn't start moving if PWM value was below value of 70)
if (motorSpeedA < 70) {
motorSpeedA = 0;
if (motorSpeedB < 70) {
motorSpeedB = 0;
analogWrite(enA, motorSpeedA); // Send PWM signal to motor A
analogWrite(enB, motorSpeedB); // Send PWM signal to motor B
// problems: buttonState, placement of buttons //
// connecting the buttons to the arduino is now above ^ //
// check if the pushbutton is pressed //
[code]if (analogRead(button1) => 500) {
buttonState1 = HIGH;
else if (analogRead(button2) => 500) {
buttonState2 = HIGH;
else if (analogRead(button3) => 500) {
buttonState3 = HIGH;
else if (analogRead(button4) => 500) {
buttonState4 = HIGH;
else ( (buttonState1 < 50) && ( buttonState2 < 50) ) {
analogWrite(enAb, 0); // How to send speed
else ( (buttonState3 < 50) && ( buttonState4 < 50) ) {
analogWrite(enBb, 0); // How to send speed
if (buttonState1 == HIGH) { //change buttonState to LOW if its backwards //
digitalWrite(in1b, HIGH);
digitalWrite(in2b, LOW);
analogWrite(enAb, 255);
if (buttonState2 == HIGH) {
digitalWrite(in1b, LOW);
digitalWrite(in2b, HIGH);
if (buttonState3 == HIGH) {
digitalWrite(in3b, HIGH);
digitalWrite(in4b, LOW);
analogWrite(enBb, 255);
if (buttonState4 == HIGH) {
digitalWrite(in3b, LOW);
digitalWrite(in4b, HIGH);
