Why is that when i program the two motors to run, one runs first and then the other runs. How do I eliminate this time lag and make them run simultaneously? I'm using the adafruit motor shield V1.
Please tell me how to write the code to make them run at the same time with no time lag.
kebo
August 10, 2016, 5:59pm
#2
Because you've programmed it that way
change your code
By posting your code so we know what you are doing wrong.
My crystal ball says that the problem is on line 42 of the code that was not posted.
J-M-L
August 10, 2016, 11:54pm
#4
Remove the delays() you have in your code that we don't see and study multiple things at the same time
This happens when the Straight() function is called
int const RS = A0; // Right sensor connected to pin A0
int const LS= A3; // Left sensor connected to pin A3
#include <AFMotor.h>
AF_DCMotor r_motor(3); // Right motor connected to port 3
AF_DCMotor l_motor(4); // Left motor connected to port 4
void setup(){
pinMode(RS, INPUT);
pinMode(LS, INPUT);
//Intitializing pin A0 and A3 as inputs
void loop(){
bool r_state = digitalRead(A0);
bool l_state = digitalRead(A3);
if((r_state == false) && (l_state == false)){
Straight();
if((r_state == true) && (l_state == false)){
Turn_Right();
if((l_state == true) && (r_state == false)){
Turn_Left();
if(l_state && r_state ){
Stop();
void Straight(){
l_motor.setSpeed(200);
r_motor.setSpeed(200);
void Turn_Right(){
r_motor.run(FORWARD);
l_motor.run(BACKWARD);
void Turn_Left(){
l_motor.run(FORWARD);
r_motor.run(BACKWARD);
void Stop(){
l_motor.setSpeed(0);
r_motor.setSpeed(0);
r_motor.run(RELEASE);
l_motor.run(RELEASE);
system
August 11, 2016, 7:07am
#6
What does your power wiring look like?
Also noticed that when the Straight Function is called the left wheel moves forward and the right wheel moves backwards. Although this happens the Turn_Right and Turn_Left functions work perfectly. Can anyone explain this
What is the point of defining LS and RS, but using A0 and A3 ?
J-M-L
August 12, 2016, 3:41am
#10
mandax_25:
That's because you miss
In the Straight Function
vaj4088:
I'm using the adafruit motor shield(v1).... that's why I've used the analog pins as digital ins
vaj4088
August 12, 2016, 11:27am
#12
Using analog pins as digital pins is fine, BUT...
if you are going to define LS and RS, then A0 and A3 should not appear elsewhere in the code. It defeats the purpose of defining LS and RS.
