Making Two LED's Pulse Without Delay
Hi Ive got two 12v Led Lights hooked up to my arduino mega through a pair of N channel MOSFETS.
I am trying to make one light flash 3 times in 75 millisecond pulses then repeat on the other light.
It all works fine, I want to remove the delay so i can use it on my robot without it pausing the code with delays. Ive looked at the blink without delay sketch (http://arduino.cc/en/Tutorial/BlinkWithoutDelay) but I'm not sure how to integrate it into my code.
  Blink
  Turns on an LED on for one second, then off for one second, repeatedly.
  This example code is in the public domain.
 int del;
  // initialize the digital pin as an output.
  // Pin 34 and 35 has an LED connected:
  pinMode(34, OUTPUT);
  pinMode(35, OUTPUT);
del = 75;
left();
off();
left();
off();
left();
off();
right();
off();
right();
off();
right();
off();
void left(){
  digitalWrite(34, HIGH);   // set the first LED on
  digitalWrite(35, LOW);   // set the second LED off
  delay(del);              // wait for a 75 milliseconds
void right(){
  digitalWrite(34, LOW);   // set the first LED off
  digitalWrite(35, HIGH);   // set the second LED on
void off(){
If someone could give me some help it would be muchly appreciated. Cheers, Alex :)
Play around with the Blink Without Delay code until you completely understand it. Tweak things until you're comfortable with every aspect of it. It's such a fundamental concept that not knowing is doing yourself a disservice.
http://www.gammon.com.au/blink
