hi everyone!
my name is taehyung, in south korea..
i have a problem in my project short pulse generate.
#include "asf.h"
#include "conf_board.h"
#include "conf_clock.h"
#define STRING_EOL "\r"
#define STRING_HEADER "--TC capture waveform Example --\r\n" \
"-- "BOARD_NAME " --\r\n" \
"-- Compiled: "__DATE__ " "__TIME__ " --"STRING_EOL
#define TC_CAPTURE_TIMER_SELECTION TC_CMR_TCCLKS_TIMER_CLOCK3
#define TC_CHANNEL_6 6
#define TC_CHANNEL_7 7
#define TC_CHANNEL_8 8
struct waveconfig_t {
/** Internal clock signals selection. */
uint32_t ul_intclock;
/** Waveform frequency (in Hz). */
uint16_t us_frequency;
/** Duty cycle in percent (positive).*/
uint16_t us_dutycycle;
/** TC waveform configurations */
static const struct waveconfig_t gc_waveconfig[] = {
{TC_CMR_TCCLKS_TIMER_CLOCK4, 178, 30},
{TC_CMR_TCCLKS_TIMER_CLOCK3, 375, 50},
{TC_CMR_TCCLKS_TIMER_CLOCK3, 800, 75},
{TC_CMR_TCCLKS_TIMER_CLOCK2, 1000, 80},
{TC_CMR_TCCLKS_TIMER_CLOCK2, 4000, 55}
#if (SAM4L)
/* The first one is meaningless */
static const uint32_t divisors[5] = { 0, 2, 8, 32, 128};
#else
/* The last one is meaningless */
static const uint32_t divisors[5] = { 2, 8, 32, 128, 0};
#endif
/** Current wave configuration*/
static uint8_t gs_uc_configuration = 0;
/** Number of available wave configurations */
const uint8_t gc_uc_nbconfig = sizeof(gc_waveconfig)
/ sizeof(struct waveconfig_t);
/** Capture status*/
static uint32_t gs_ul_captured_pulses;
static uint32_t gs_ul_captured_ra;
static uint32_t gs_ul_captured_rb;
* \brief Display the user menu on the UART.
static void display_menu(void)
uint8_t i;
puts("\n\rMenu :\n\r"
"------\n\r"
" Output waveform property:\r");
for (i = 0; i < gc_uc_nbconfig; i++) {
printf(" %d: Set Frequency = %4u Hz, Duty Cycle = %2u%%\n\r", i,
(unsigned int)gc_waveconfig[i].us_frequency,
(unsigned int)gc_waveconfig[i].us_dutycycle);
printf(" -------------------------------------------\n\r"
" c: Capture waveform from TC%d channel %d\n\r"
" s: Stop capture and display captured informations \n\r"
" h: Display menu \n\r"
"------\n\r\r", TC_PERIPHERAL,TC_CHANNEL_CAPTURE);
* \brief Configure TC TC_CHANNEL_WAVEFORM in waveform operating mode.
static void tc_waveform_initialize(void)
uint32_t ra, rc;
/* Configure the PMC to enable the TC module. */
sysclk_enable_peripheral_clock(ID_TC6);
/* Init TC to waveform mode. */
tc_init(TC2, TC_CHANNEL_8,
/* Waveform Clock Selection */
gc_waveconfig[gs_uc_configuration].ul_intclock
| TC_CMR_WAVE /* Waveform mode is enabled */
| TC_CMR_ACPA_SET /* RA Compare Effect: set */
| TC_CMR_ACPC_CLEAR /* RC Compare Effect: clear */
| TC_CMR_CPCTRG /* UP mode with automatic trigger on RC Compare */
/* Configure waveform frequency and duty cycle. */
rc = (sysclk_get_peripheral_bus_hz(TC2) /
divisors[gc_waveconfig[gs_uc_configuration].ul_intclock]) /
gc_waveconfig[gs_uc_configuration].us_frequency;
tc_write_rc(TC2, TC_CHANNEL_8, rc);
ra = (100 - gc_waveconfig[gs_uc_configuration].us_dutycycle) * rc / 100;
tc_write_ra(TC2, TC_CHANNEL_8, ra);
/* Enable TC TC_CHANNEL_WAVEFORM. */
tc_start(TC2, TC_CHANNEL_8);
printf("Start waveform: Frequency = %d Hz,Duty Cycle = %2d%%\n\r",
gc_waveconfig[gs_uc_configuration].us_frequency,
gc_waveconfig[gs_uc_configuration].us_dutycycle);
* \brief Configure TC TC_CHANNEL_CAPTURE in capture operating mode.
static void tc_capture_initialize(void)
/* Configure the PMC to enable the TC module */
sysclk_enable_peripheral_clock(ID_TC_CAPTURE);
/* Init TC to capture mode. */
tc_init(TC, TC_CHANNEL_CAPTURE,
TC_CAPTURE_TIMER_SELECTION /* Clock Selection */
| TC_CMR_LDRA_RISING /* RA Loading: rising edge of TIOA */
| TC_CMR_LDRB_FALLING /* RB Loading: falling edge of TIOA */
| TC_CMR_ABETRG /* External Trigger: TIOA */
| TC_CMR_ETRGEDG_FALLING /* External Trigger Edge: Falling edge */
* \brief Interrupt handler for the TC TC_CHANNEL_CAPTURE
void TC_Handler(void)
if ((tc_get_status(TC, TC_CHANNEL_CAPTURE) & TC_SR_LDRBS) == TC_SR_LDRBS) {
gs_ul_captured_pulses++;
gs_ul_captured_ra = tc_read_ra(TC, TC_CHANNEL_CAPTURE);
gs_ul_captured_rb = tc_read_rb(TC, TC_CHANNEL_CAPTURE);
* Configure UART console.
static void configure_console(void)
const usart_serial_options_t uart_serial_options = {
.baudrate = CONF_UART_BAUDRATE,
#ifdef CONF_UART_CHAR_LENGTH
.charlength = CONF_UART_CHAR_LENGTH,
#endif
.paritytype = CONF_UART_PARITY,
#ifdef CONF_UART_STOP_BITS
.stopbits = CONF_UART_STOP_BITS,
#endif
/* Configure console UART. */
stdio_serial_init(CONF_UART, &uart_serial_options);
* \brief Application entry point for tc_capture_waveform example.
* \return Unused (ANSI-C compatibility).
uint32_t tc_read_cmr(Tc *p_tc, uint32_t ul_channel)
Assert(ul_channel <
(sizeof(p_tc->TC_CHANNEL) / sizeof(p_tc->TC_CHANNEL[0])));
return p_tc->TC_CHANNEL[ul_channel].TC_CMR;
int main(void)
uint8_t key;
uint16_t frequence, dutycycle;
/* Initialize the SAM system */
sysclk_init();
board_init();
/* Initialize the console uart */
configure_console();
/* Output example information */
printf("-- TC capture waveform Example --\r\n");
printf("-- %s\n\r", BOARD_NAME);
printf("-- Compiled: %s %s --\n\r", __DATE__, __TIME__);
/* Configure PIO Pins for TC */
ioport_set_pin_mode(PIO_PD7_IDX, IOPORT_MODE_MUX_B);
/* Disable IO to enable peripheral mode) */
ioport_disable_pin(PIO_PD7_IDX);
ioport_set_pin_mode(PIN_TC_CAPTURE, PIN_TC_CAPTURE_MUX);
ioport_disable_pin(PIN_TC_CAPTURE);
/* Configure TC TC_CHANNEL_WAVEFORM as waveform operating mode */
printf("Configure TC%d channel %d as waveform operating mode \n\r",
TC_PERIPHERAL, TC_CHANNEL_WAVEFORM);
tc_waveform_initialize();
/* Configure TC TC_CHANNEL_CAPTURE as capture operating mode */
printf("Configure TC%d channel %d as capture operating mode \n\r",
TC_PERIPHERAL, TC_CHANNEL_CAPTURE);
tc_capture_initialize();
/* Configure TC interrupts for TC TC_CHANNEL_CAPTURE only */
NVIC_DisableIRQ(TC_IRQn);
NVIC_ClearPendingIRQ(TC_IRQn);
NVIC_SetPriority(TC_IRQn, 0);
NVIC_EnableIRQ(TC_IRQn);
/* Display menu */
display_menu();
printf("check register : %x %x %x \n\r", tc_read_ra(TC2, TC_CHANNEL_6), tc_read_rc(TC2, TC_CHANNEL_6), tc_read_cmr(TC2, TC_CHANNEL_6));
while (1) {
scanf("%c", (char *)&key);
switch (key) {
case 'h':
display_menu();
case 's':
if (gs_ul_captured_pulses) {
tc_disable_interrupt(TC, TC_CHANNEL_CAPTURE, TC_IDR_LDRBS);
printf("Captured %u pulses from TC%d channel %d, RA = %u, RB = %u \n\r",
(unsigned)gs_ul_captured_pulses, TC_PERIPHERAL,
TC_CHANNEL_CAPTURE, (unsigned)gs_ul_captured_ra,
(unsigned)gs_ul_captured_rb);
frequence = (sysclk_get_peripheral_bus_hz(TC) /
divisors[TC_CAPTURE_TIMER_SELECTION]) /
gs_ul_captured_rb;
dutycycle
= (gs_ul_captured_rb - gs_ul_captured_ra) * 100 /
gs_ul_captured_rb;
printf("Captured wave frequency = %d Hz, Duty cycle = %d%% \n\r",
frequence, dutycycle);
gs_ul_captured_pulses = 0;
gs_ul_captured_ra = 0;
gs_ul_captured_rb = 0;
puts("No waveform has been captured\r");
puts("\n\rPress 'h' to display menu\r");
case 'c':
puts("Start capture, press 's' to stop \r");
tc_enable_interrupt(TC, TC_CHANNEL_CAPTURE, TC_IER_LDRBS);
/* Start the timer counter on TC TC_CHANNEL_CAPTURE */
tc_start(TC, TC_CHANNEL_CAPTURE);
default:
/* Set waveform configuration #n */
if ((key >= '0') && (key <= ('0' + gc_uc_nbconfig - 1))) {
if (!gs_ul_captured_pulses) {
gs_uc_configuration = key - '0';
puts("Capturing ... , press 's' to stop capture first \r");
the code above is example TC_TC_CAPTURE_WAVEFORM_EXAMPLE offered form atmel studio..
already i succeed using tc_channel 0~tc_channel 2 included in TC0
according to the manual ATSAM3X8E support TC0 and TC2 .
so first, i change code simply only regarded tc_waveforms. but the tc_channel 6~8 are naver work. ??
if you are expert and know solvation ... please reply for me.. thank you!
