Malfunction of Wifi Shield with the Microchip module MRF24WB0MA (broken?)
Hello to all
I recently purchased a WiFi Shield for Arduino that I've tried both with Arduino UNO R2 and R3
First, the malfunction found: the LED on the Shield lights up the shield for 8 seconds (approximately),
stays off for 5 seconds (approximately), and lights up again for 8 secs, and so on ... clearly the connection there isn't in any way
I did some testing with various IDE (with the latest on website arduino.cc, and with 0023)
I tried both with the libraries "asynclabs-WiShield-v1.3.0-0" and with the "WiShield_user_contrib-master" .. but nothing to do!
clearly I customized the sketch with the parameters of my network ... (I tried to use it as a WebServer, setting the appropriate file "apps-conf.h")
I'm thinking that may be damaged by the welding of the strip on the card (excessive heat? .. welds seem ok)
If someone is using it, with what combination of ArduinoUNO +IDE+libraries the WifiShield is working??
thanks
Don't bother posting in Italian here. If you get an answer in Italian it will have to be moved to the Italian section. This section is for English.
How to use this forum
