Malfunzionamento lcd
Buona sera ragazzi, ma a qualcuno è mai capitata una roba del genere??
Lo sketch è il classico hello world preso dal sito di arduino
ma mi sorge un dubbio per lcd bisogna scaricare qualche libreria??
Ma va ... :grin:
Come è collegato il LCD ... parallelo o via I2C?
A giudicare dai pochi fili che vedo spero che sia I2C, comunque, per entrambi ci sono specifiche librerie, quindi, dicci come è collegato e vediamo la libreria da usare ... :wink:
Guglielmo
e collegato banalmente cosi:
e questo è lo sketch
  LiquidCrystal Library - Hello World
 Demonstrates the use a 16x2 LCD display.  The LiquidCrystal
 library works with all LCD displays that are compatible with the
 Hitachi HD44780 driver. There are many of them out there, and you
 can usually tell them by the 16-pin interface.
 This sketch prints "Hello World!" to the LCD
 and shows the time.
  The circuit:
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
 * LCD R/W pin to ground
 * LCD VSS pin to ground
 * LCD VCC pin to 5V
 * 10K resistor:
 * ends to +5V and ground
 * wiper to LCD VO pin (pin 3)
 Library originally added 18 Apr 2008
 by David A. Mellis
 library modified 5 Jul 2009
 by Limor Fried (http://www.ladyada.net)
 example added 9 Jul 2009
 by Tom Igoe
 modified 22 Nov 2010
 by Tom Igoe
 modified 7 Nov 2016
 by Arturo Guadalupi
 This example code is in the public domain.
 http://www.arduino.cc/en/Tutorial/LiquidCrystalHelloWorld
// include the library code:
#include <LiquidCrystal.h>
// initialize the library by associating any needed LCD interface pin
// with the arduino pin number it is connected to
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // Print a message to the LCD.
  lcd.print("hello, world!");
  // set the cursor to column 0, line 1
  // (note: line 1 is the second row, since counting begins with 0):
  lcd.setCursor(0, 1);
  // print the number of seconds since reset:
  lcd.print(millis() / 1000);
Ok, quindi è un LCD parallelo, la prossima volta prendilo con l'adattatore I2C (costa un'inezia di più) che così usi solo 2 pin per comandarlo ...
Comunque ... stia già usando una libreria ... basta che leggi il sorgente:
... quindi deve essere una questione di collegamenti sbagliati (sono descritti nel commento del codice che hai pubblicato); riverifica esattamente i vari pin che hai connesso e controlla facciano bene contatto nella breadboard.
Guglielmo
Era quello nell’ scatola del beginner kit
Ora provo a ricontrollare i collegamenti più che altro che non siamo rotti i fili
Possibile che sia rotto proprio lo schermo ?
Non credo, quelli che sta visualizzando sono dei caratteri NON mappati nella tabella interna dei caratteri visualizzabili ... la cosa più probabile è che NON arrivi un bit di dati ... :roll_eyes:
Guglielmo
Comunque già non torna l'immagine dei collegamenti che hai pubblicato con il relativo codice: nel disegno vedo fili collegati ai pin 10 e 11, nello sketch sono dichiarati 11 e 12.
Ciao, Ale.
Si probabilmente ho preso il primo schema che ho trovato in rete ma sono giusti con il codice… alla fine a quali pin serve avere il pwm?
Ah, grazie per l'impegno, auguri per la soluzione... :roll_eyes:
Ciao, Ale.
Lascia stare il PWM che NON ti serve (almeno al momento) e fai funzionare il LCD mettendo schemi, collegamenti e foto che mostrino bene le connessioni.
Guglielmo
dai ma mica te la sarai presa??? i collegamenti li ho fatti ieri sera non ho ritrovato lo stesso post
Ho provato a caricare crystall balls uno degli sketch prevaricati di arduino e mi stampa questo
ho appena riprovato a cambiare tutti i collegamenti, ma nada, secondo me è morto proprio lui
Puoi fare uno schema ESATTO dei collegamenti reali che hai fatto ... perché, se quando li fai usi 4 fili bianchi ... non è che noi dalle foto riusciamo a capire piû di tanto ... :roll_eyes:
Metti un link a questo prodotto ... così capiamo di quale kit esattamente si tratta (ce ne sono un'infinità).
Guglielmo
https://store.arduino.cc/collections/kits/products/arduino-starter-kit-multi-language
Schema ora sono da telefono ma ho cambiato i fili di colori diversi
Comunque in poche parole non c’è un grande schema da fare :
il filo verde partendo da sx e il potenziometro
Blu 12
Grigio chiaro11
Giorgio scuro 5
Magenta 4
Blu 3
Grigio 2
Ma hai provato a regolare il contrasto?
Non dovrebbe entrarci, ma visto mai che sia troppo elevato ...
Comunque ricorda che il lato con il connettore è il sopra del display e quindi il connettore va in alto per la corretta lettura :wink:
Guglielmo
P.S.: QUI trovi il datasheet di quel LCD e, a pag. 16 il significato dei vari pin ... verifica.
Vuoi mica dirmi che ho messo i connettori al contrario?
