Manchester encoding
Hello-
I would like to send data between two Arduino Unos. I plan on using the manchester encoding library located here.
https://mchr3k.github.io/arduino-libs-manchester/
For initial understanding I would like to send using the serial monitor on one board and receive using the serial monitor on the other board.
Can I connect the tx pin on one board directly to the rx pin on the other?
Thank
you
Yes. Don't forget to connect the grounds, too.
