Manchester library on 32U4
Hello all
I am having no joy getting the Manchester Library (https://github.com/mchr3k/arduino-libs-manchester) to work on 32u4 based arduinos (leonardo and yun).
It works great on 328 Uno and Attiny85 but I can get it to receive on the Yun or leonardo. I have tried all pins. I am using 433mhz tx/rx units from spark fun.
The library says it support the 32u4 so I'm really confused.
Any ideas?
Cheers
Ben
Please provide the sketch you're doing your tests with. The library supports the ATmega32U4, so it shouldn't be an unsolvable problem. Also provide a wiring diagram or a sharp photo of your setup.
Does the sending part work on the ATmega32U4 based Arduinos? Are you using other libraries that may use Timer3?
