hadwll
October 27, 2019, 8:00am
1
Hi..
The scenario is as so, I have one MKR1000 board that is measuring temp and humidity packing it up from Float to String and sending it to a second MKR1000 board were I want to be able to manipulate it.
I have the following output on the serial monitor of the receiving board.
the 2 numbers are sensor values. presently as String data type.
I would like them as separate float variables presently they are received at the same time via the following code.
I had thought about splitting the "payload" string into 2 different character arrays then into 2 floats but I can't figure the code.
void messageReceived(String &topic, String &payload) {
Serial.println(payload);
the whole code as below, the message is received from another MKR1000 board that is measuring the values and sending them over MQTT.
26/10 began commenting
/////// Libaries \\\\\\\
#include <SPI.h>
#include <WiFi101.h>
#include <MQTT.h>
/////// setup WiFi details\\\\\\\
const char ssid[] = "";
const char pass[] = "";
///////Variables to take values from received variables\\\\\\\
unsigned long lastMillis = 0;
String payload;
WiFiClient net;
MQTTClient client;
void connect() {
Serial.print("checking wifi...");
Serial.print(".");
Serial.print("\nconnecting...");
while (!client.connect("arduino", "try", "try")) {
Serial.print(".");
Serial.println("\nconnected!");
client.subscribe("TempTopic");
client.subscribe("HumidityTopic");
// client.unsubscribe("/hello");
WiFi.begin(ssid, pass);
client.begin("broker.shiftr.io", net);
connect();
client.loop();
client.onMessage(messageReceived);
if(!client.connected()) {
connect();
and one other thing to clarify..
do MQTT messages have to be sent as String data type?
Apologies if the code is sloppy I have not figured a standard as yet.
Ta.
J-M-L
October 27, 2019, 11:44am
2
hadwll:
you do#include <MQTT.h>
which MQTT library is that?
if this is that one , the doc describes those API:
// Publishes a message to the broker with an optional payload:
bool publish(const String &topic);
bool publish(const char topic[]);
bool publish(const String &topic, const String &payload);
bool publish(const String &topic, const String &payload, bool retained, int qos);
bool publish(const char topic[], const String &payload);
bool publish(const char topic[], const String &payload, bool retained, int qos);
bool publish(const char topic[], const char payload[]);
bool publish(const char topic[], const char payload[], bool retained, int qos);
bool publish(const char topic[], const char payload[], int length);
bool publish(const char topic[], const char payload[], int length, bool retained, int qos);
// Subscribe to a topic:
bool subscribe(const String &topic);
bool subscribe(const String &topic, int qos);
bool subscribe(const char topic[]);
bool subscribe(const char topic[], int qos);
hadwll
October 27, 2019, 5:07pm
3
Thanks, it is the same library. I will study this and see if I can work out how to utilize it!
J-M-L
October 27, 2019, 6:13pm
4
probably this one
could be used to publish a binary message
hadwll
October 28, 2019, 6:24am
5
So I had a look this morning could you help me understand what is going on?
I understand that I need to use the piece of code that you have lined up above. The only place I can find code similar to that is in the header file.
I see them all listed there. I can't figure out how to run a specific line.
however, I do see this advanced callback... which is the one I need.
typedef void (*MQTTClientCallbackSimple)(String &topic, String &payload);
typedef void (*MQTTClientCallbackAdvanced)(MQTTClient *client, char topic[], char bytes[], int length);
how do I call the advance callback opposed to the simple..
in my code, I have this function
Serial.println("incoming: " + topic + " - " + payload);
and this
which relate to here in the header file I guess?
(I tried changing the ".onMessage" to".onMessageAdvanced" to no avail.
void onMessage(MQTTClientCallbackSimple cb);
void onMessageAdvanced(MQTTClientCallbackAdvanced cb);
I'm struggling to put it all together though.
Thanks.
hadwll
October 29, 2019, 6:07am
6
solution...
call- client.onMessageAdvanced(messageReceived);
function void messageReceived(MQTTClient *client, char topic[], char payload[], int payload_length) {
and now I am going to try and split the payload with a for loop...
for (byte i = 0; i < payload_length; i++) {
Serial.print((char)payload[i]);
and then convert the char array to float...
hopefully
