Kionko
December 4, 2015, 8:17pm
1
Hi guys! New here in the forums and new with the arduino, so i got a question for you.
I have an Manometer program that i did for arduino, that converts analog to int type 10 bits, but now i want to reverse the function, how do i do that with this program?
#define INTERVAL 1000
int x;
int timestamp;
float TEN2FLOAT (int val) {
return (val*5.0)/1023.0;
void metodo2(){
void VOLTMETER() {
x = analogRead(A0); //Lê os valores analogicos
if (millis() - timestamp < INTERVAL)
return;
else {
timestamp = millis();
Serial.print(timestamp);
Serial.print(" , ");
Serial.println(TEN2FLOAT(x), 3);
void MANOMETER(){
return;
else {
Serial.println(TEN2FLOAT(x));
//VOLTMETER();
MANOMETER();
Please use the "</>" Button to encapsulate your Code.
Kionko
December 4, 2015, 11:46pm
3
Sorry. Here it is (it has some portuguese words)
int x;
int timestamp;
void metodo2(){
void VOLTMETER() {
return;
else {
void MANOMETER(){
return;
else {
//VOLTMETER();
MANOMETER();
Kionko
December 5, 2015, 12:42am
5
I want to reconvert the digital value (int 10 bits) to float VOLTAGE between 0 and 5
float voltage = 5.0*digitalValue/1024;
Kionko
December 5, 2015, 2:33pm
7
Then i do a serial print VOLTAGE right? (BTW ignore void VOLTMETER, that is from other exercise of the project)
Kionko:
Really, in the time it took you to post that, you could have tried it.
Kionko
December 5, 2015, 4:48pm
9
