Manual Arduino Due Installation - Bossac Location
Hello All,
I have installed the Arduino Due package manually, as there are issues with my firewall.
I seem to have successfully installed everything, however when I attempt to upload to the Due, the system faults out with the following message:
java.io.IOException: Cannot run program "___REMOVE___/bossac.exe": CreateProcess error=2, The system cannot find the file specified
	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
	at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:26)
	at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
	at cc.arduino.packages.uploaders.SerialUploader.runCommand(SerialUploader.java:383)
	at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:197)
	at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
	at processing.app.SketchController.upload(SketchController.java:732)
	at processing.app.SketchController.exportApplet(SketchController.java:703)
	at processing.app.Editor$UploadHandler.run(Editor.java:2075)
	at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: CreateProcess error=2, The system cannot find the file specified
	at java.lang.ProcessImpl.create(Native Method)
	at java.lang.ProcessImpl.<init>(ProcessImpl.java:386)
	at java.lang.ProcessImpl.start(ProcessImpl.java:137)
	at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
	... 9 more
An error occurred while uploading the sketch
Meanwhile, I can successfully flash the Due if I Export Compiled Binary and then flash manually using Bossac, located in:
C:\Users\USERNAME\AppData\Local\Arduino15\packages\arduino\tools\bossac\1.6.1-arduino
I navigate Command Prompt to this location and use command line to flash.
Any Ideas?
Thanks
