Manually add configuration to board.txt
I want to add an additional configuration to the boards.txt for the "Arduino Pro or Pro Mini"
I will usese for some project with watchdog the optiboot bootloader
i have change the first entry for the 16MHZ 5V like this (the + sign is not in the boards txt, this is the added line)
pro.menu.cpu.16MHzatmega328=ATmega328 (5V, 16 MHz)*
pro.menu.cpu.16MHzatmega328.upload.maximum_size=30720*
pro.menu.cpu.16MHzatmega328.upload.maximum_data_size=2048*
#pro.menu.cpu.16MHzatmega328.upload.speed=57600*
+pro.menu.cpu.16MHzatmega328.upload.speed=115200*
pro.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF*
pro.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA*
pro.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x05*
#pro.menu.cpu.16MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex*
+pro.menu.cpu.16MHzatmega328.bootloader.file=optiboot/optiboot_atmega328.hex*
pro.menu.cpu.16MHzatmega328.build.mcu=atmega328p*
pro.menu.cpu.16MHzatmega328.build.f_cpu=16000000L*
it works fine, in my next step i added a new entry with a unique name
pro.menu.cpu.16MHzatmega328=ATmega328 (5V, 16 MHz) opti*
pro.menu.cpu.op16MHzatmega328.upload.maximum_size=30720*
pro.menu.cpu.op16MHzatmega328.upload.maximum_data_size=2048*
pro.menu.cpu.op16MHzatmega328.upload.speed=115200*
pro.menu.cpu.op16MHzatmega328.bootloader.low_fuses=0xFF*
pro.menu.cpu.op16MHzatmega328.bootloader.high_fuses=0xDA*
pro.menu.cpu.op16MHzatmega328.bootloader.extended_fuses=0x05*
pro.menu.cpu.op16MHzatmega328.bootloader.file=optiboot/optiboot_atmega328.hex*
pro.menu.cpu.op16MHzatmega328.build.mcu=atmega328p*
pro.menu.cpu.op16MHzatmega328.build.f_cpu=16000000L*
unfortunalty this will not work
i get this error message (error to burn the bootoader)
"Fehler beim Brennen des Bootloaders.
avrdude: AVR Part "{build.mcu}" not found.
Valid parts are:
uc3a0512 = AT32UC3A0512
c128 = AT90CAN128
c32 = AT90CAN32
is there annother file which is my unique name "op16MHzatmega328" linked to
thank in forwar for your support, i have no idea
Lutz
issue seems solved, I don't know why, I think it is the same like before, but during the test with the 5th entry one connection was wrong, after this the system rest of the computer maybe the solution
But this is only about the error message to burn the bootload. unfortunately the upload of the sktech does not work.
pro.name=Arduino Pro or Pro Mini
pro.upload.tool=avrdude
pro.upload.protocol=arduino
pro.bootloader.tool=avrdude
pro.bootloader.unlock_bits=0x3F
pro.bootloader.lock_bits=0x0F
pro.build.board=AVR_PRO
pro.build.core=arduino
pro.build.variant=eightanaloginputs
## Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega328P
pro.menu.cpu.16MHzatmega328=ATmega328P (5V, 16 MHz)
pro.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0xFD
## Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega328P
pro.menu.cpu.8MHzatmega328=ATmega328P (3.3V, 8 MHz)
pro.menu.cpu.8MHzatmega328.upload.maximum_size=30720
pro.menu.cpu.8MHzatmega328.upload.maximum_data_size=2048
pro.menu.cpu.8MHzatmega328.upload.speed=57600
pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xFF
pro.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
pro.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0xFD
pro.menu.cpu.8MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
pro.menu.cpu.8MHzatmega328.build.mcu=atmega328p
pro.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
## Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega168
pro.menu.cpu.16MHzatmega168=ATmega168 (5V, 16 MHz)
pro.menu.cpu.16MHzatmega168.upload.maximum_size=14336
pro.menu.cpu.16MHzatmega168.upload.maximum_data_size=1024
pro.menu.cpu.16MHzatmega168.upload.speed=19200
pro.menu.cpu.16MHzatmega168.bootloader.low_fuses=0xff
pro.menu.cpu.16MHzatmega168.bootloader.high_fuses=0xdd
pro.menu.cpu.16MHzatmega168.bootloader.extended_fuses=0xF8
pro.menu.cpu.16MHzatmega168.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
pro.menu.cpu.16MHzatmega168.build.mcu=atmega168
pro.menu.cpu.16MHzatmega168.build.f_cpu=16000000L
## Arduino Pro or Pro Mini (3.3V, 8 MHz) w/ ATmega168
pro.menu.cpu.8MHzatmega168=ATmega168 (3.3V, 8 MHz)
pro.menu.cpu.8MHzatmega168.upload.maximum_size=14336
pro.menu.cpu.8MHzatmega168.upload.maximum_data_size=1024
pro.menu.cpu.8MHzatmega168.upload.speed=19200
pro.menu.cpu.8MHzatmega168.bootloader.low_fuses=0xc6
pro.menu.cpu.8MHzatmega168.bootloader.high_fuses=0xdd
pro.menu.cpu.8MHzatmega168.bootloader.extended_fuses=0xF8
pro.menu.cpu.8MHzatmega168.bootloader.file=atmega/ATmegaBOOT_168_pro_8MHz.hex
pro.menu.cpu.8MHzatmega168.build.mcu=atmega168
pro.menu.cpu.8MHzatmega168.build.f_cpu=8000000L
## Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega328P optibootloader
pro.menu.cpu.16MHzatmega328opt=ATmega328P (5V, 16 MHz) optiboot
pro.menu.cpu.16MHzatmega328opt.upload.maximum_size=30720
pro.menu.cpu.16MHzatmega328opt.upload.maximum_data_size=2048
pro.menu.cpu.16MHzatmega328opt.upload.speed=115200
pro.menu.cpu.16MHzatmega328opt.bootloader.low_fuses=0xFF
pro.menu.cpu.16MHzatmega328opt.bootloader.high_fuses=0xDA
pro.menu.cpu.16MHzatmega328opt.bootloader.extended_fuses=0xFD
pro.menu.cpu.16MHzatmega328opt.bootloader.file=optiboot/optiboot_atmega328.hex
pro.menu.cpu.16MHzatmega328opt.build.mcu=atmega328p
pro.menu.cpu.16MHzatmega328opt.build.f_cpu=16000000L
yes such a foolishness, i have 20 arduino pro mini 16Mhz 5V and one 8Mhz 3.3V, it works fine with the 5V type but in the application mistakenly my only 3.3V type
