Hi everybody,
I have recently bought a wireless weather station (the Buienradar BR-1000), but I want to read out the sensors manually so I can log the data. I found out that the rain sensor and the anemometer use reed switches which I can connect to the Arduino, but I'm having trouble identifying the sensors on the wind vane. They seem to be very unlike other wind vanes I found online.
The wind vane is connected to a tube with a slot. The tube is placed over a number of what look like receivers. On the outside of the tube are (I think) LEDs (see pictures below). The PCB has a total of eight wires attached to it.
The problem is that I cannot find out how it works and how the wires are connected. I tried testing the LEDs by applying some current to them directly, but that didn't seem to work. I also used a camera to check if they were IR leds, but I didn't see anything. The receivers also don't look like regular IR receivers or photoresistors because the receivers appear to be entirely flat. In addition to that the receivers have three pins instead of the regular two, so I'm not sure what they are and how they should be connected.
My question is, does anybody know (for certain) what these sensors are and how they should be connected?
Thanks a lot in advance!
