Manually upload code to Arduino YUN (atemega32u4)
I've been struggling for couple of weeks on a seemingly easy task - I'm trying to manually compile an arduino sketch and upload to my new Arduino Yun board (with atemega32u4). Right now I've found appropriate command and been able compile up until a main.hex file, I compare the .hex file with the one that is made by Arduino application and they are the same.
However, when I try to upload the .hex file to the board, I'm constantly getting error message saying that my butterfly programmer is not responding.
The code I was using is:
/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C /Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -p atmega32u4 -cavr109 -P/dev/tty.usbmodem1421 -b19200 -D -Uflash:w:LED_blink_c.cpp.hex :i
and it will return:
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/Ian/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/tty.usbmodem1421
Using Programmer : avr109
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 10 8 0 no 1024 8 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: Send: . [1b]
avrdude: Send: S [53]
avrdude: ser_recv(): programmer is not responding
avrdude: butterfly_recv(): programmer is not responding
Right now I've tried multiple baud rate but no luck... What I'm very curious is that by running "->" on the arduino application 1.5.5, everything runs specifically smooth and easy, but I just got stuck at this stage with no clue why things stop working.
Any help will be appreciated... :slight_smile:
