Many "expected `)' before ';' token" errors
Read up on functions and parameter passing: (an example)
Adding "int face" inside the parenthesis of the cycle function definition signals that the function should expect a parameter named face, with a type of int. The function than can reference that parameter as face in the function body.
When you call the function, you put a parameter value inside the parenthesis:
  • cycle(0) will result in face having the value 0
  • cycle(100) will result in face having the value of 100
  • cycle(frontFace) will result in face having the current value of frontFace
  • cycle(rightFace) will result in face having the current value of rightFace
You can think of it as declaring a local variable in the function, and initializing that variable with the value that was passed in when the function is called. The key is that the initial value of the "face" variable will change at run time according to how it was called.
You'd need to consider a delay after the servo write to allow the servo to reach the position written.
ShapeShifter:
Noted, so when the function is called, it will result in cmFace being whatever the function returns?
AWOL:
ShapeShifter:
So the code should look like this now, right?
#include <Servo.h>
Servo servo;
#define trigPin 3; // Trig Pin (Digital)
#define echoPin 2; // Echo Pin (Digital)
int alertRange = 30; // alert rainge in cm
// #define maximumRange 10000;
// #define minimumRange 0;
long duration, cmFront, cmLeft, cmRight; // Duration used to calculate distance
  servo.attach(9);
  // Test the servo before begining
  servoTest();
  int frontFace = 85; // The Servo's front facing angle
  int rightFace = 40; // The Servo's right facing angle
  int leftFace = 130; // The Servo's left facing angle
  cmFront = cycle(frontFace);
  cmLeft = cycle(leftFace);
  cmRight = cycle(rightFace);
  Serial.print("Front: ");
  Serial.print(cmFront);
  Serial.print("Left: ");
  Serial.print(cmLeft);
  Serial.print("Right: ");
  Serial.println(cmRight);
void servoTest()
  servo.write(frontFace);
  servo.write(rightFace);
  servo.write(leftFace);
  servo.write(0);
  servo.write(180);
long cycle(int face)
  servo.write(face);
  delay(100);
  // Trig/Echo cycle
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(5);
  duration = pulseIn(echoPin, HIGH);
  return microsecondsToCentimeters(duration);
long microsecondsToCentimeters(long microseconds)
  // The speed of sound is 340 m/s or 29 microseconds per centimeter.
  // The ping travels out and back, so to find the distance of the
  // object we take half of the distance travelled.
  return microseconds / 29 / 2;
Yes, except you've got duplicated global and locals (variables with the same name).
This isn't a problem if you know what you're doing, but is confusing if you don't.
afroraydude:
What is cmFace?
cmFront, cmLeft, and cmRight will become whatever the function returns during the respective call.
afroraydude:
Close.
  • You do not need the global declaration of duration, cmFront, cmLeft, and cmRight on line 11.
  • You do not need the local declaration of duration inside function loop().
  • You do need a local declaration of duration inside of function cycle() if you removed the global declaration on line 11.
ShapeShifter:
What is cmFace?
Close.
ShapeShifter:
What is cmFace?
Close.
Ik, in the code i already had cmFront, cmLeft, and cmRight. I just did not want to put it in what I was saying, just lazy.
