Many sensors/timing
I have several question regarding a rather large sketch.
I have 2 potmeters and and 9 seonsor connected to analog pins through a multiplexer, then I have a pickup sensor which either is high or low with a maximum of 200 pulses per second, then i have strobe which needs to be pulsed at maximum 50Hz
So my problem is to be able to read the pulses without missing to many input pulses: readRPM()
and generate the output pulses:
strobeSpeed();
at the same time I want to log the data and scroll between the values of the analog inputs on the lcd scrren.
Does the sketch below look like a good start? It compiles, but Im not sure how to solve the task metioned above
Cheers
// Sketch for meassuring sensor on SB100
#include <ServoTimer2.h>    // the servo library
#include <lcd.h>            // the lcd library
// Debug config
long previousDebug = 0;
boolean debugOn = true;
int debugInterval = 1000;
boolean debugServo = true;
// Pin configuration
//Digital pins
int servoPin  = 13;
int strobePin =  5;
int pickUpPin =  4;
int s0        = 12;
int s1        = 12;
int s2        = 12;
int AD0       =  0;
int AD1       =  1;
int AD2       =  2;
int AD3       =  3;
int AD4       =  4;
int AD5       =  5;
// Constants for logging data
int logInterval = 1000;
long previousLog = 0;
int countPrint = 0;
// Constants for LCD diplay
long previousLCD = 0;
int scrollInterval = 1000;
// constants regarding moving the servo for the webcam
int servoPot  = 11;
int pulsWidthMin   = 1200;
int pulsWidthMax   = 1800;
boolean servoDirection = 0;
ServoTimer2 servo;
int deltaPulsWidth = pulsWidthMax - pulsWidthMin;
int pulsWidth = deltaPulsWidth/2; // this will be overidden later;
// constants for ADC with multiplexer
int r0 = 0;    //value select pin at the 4051 (s0)
int r1 = 0;    //value select pin at the 4051 (s1)
int r2 = 0;    //value select pin at the 4051 (s2)
int row = 0;   //storing the bin code
int count = 0; //counter for all the adc
int bin [] = {000,1,10,11,100,101,110,111}; //binear
int analogRef [] = {0,0,0,0,0,0,0,0,0,0,0,0,0};
// constants for strobe ...
long previousStrobePuls =  0;
int pulseSpeed          =  0;
int pulsePot            = 12;
// contants for pickup
boolean pickUp = false;
void setup(){
  //Setting pins for servo
  servo.attach(servoPin);     // attach a pin to the servos
  //Setting pins for multiplexer
  pinMode(s0,OUTPUT);
  pinMode(s1,OUTPUT);
  pinMode(s2,OUTPUT);
  lcd_init(LCD_DISP_ON);
  lcd_clrscr();
void loop(){
  readADC();
  moveServo();
  readRPM();
  strobeSpeed();
  sendLoggingData();
  showOnLCD();
  if(debugOn){
    debug();
void readRPM(){
  if(digitalRead(pickUpPin)==HIGH){
    pickUp = true;
  else {
    pickUp = false;
void strobeSpeed(){
  pulseSpeed = 1024-analogRef[pulsePot];
  if(millis()-previousStrobePuls> pulseSpeed/2){
    digitalWrite(strobePin,HIGH);
  if(millis()-previousStrobePuls> pulseSpeed){
    digitalWrite(strobePin,LOW);
    previousStrobePuls = millis();
void moveServo(){
  if(servoDirection){
    pulsWidth = (deltaPulsWidth * analogRef[servoPot])/1024 + pulsWidthMin;
  else{
    pulsWidth = pulsWidthMax - (deltaPulsWidth * analogRef[servoPot])/1024 ;
  servo.write(pulsWidth);
void readADC(){
 for(count = 0; count<8;count++){
  row = bin[count];
  r0 = row & 0x01;
  r1 = (row>>1) & 0x01;
  r2 = (row>>2) & 0x01;
  digitalWrite(s0,r0);
  digitalWrite(s1,r0);
  digitalWrite(s2,r0);
  analogRef[count] = analogRead(AD0);
 analogRef[count++] = analogRead(AD1);
 analogRef[count++] = analogRead(AD2);
 analogRef[count++] = analogRead(AD3);
 analogRef[count++] = analogRead(AD4);
 analogRef[count++] = analogRead(AD5);
void sendLoggingData(){
  if(millis()-previousLog> logInterval)
    for(countPrint = 0; countPrint<12;countPrint++){
       Serial.print(analogRef[countPrint]);
       Serial.print(",");
   Serial.println(analogRef[countPrint++]);
   previousLog = millis();
void showOnLCD(){
  if(millis()-previousLCD> scrollInterval){
   lcd_puts("P. Suction: ");
   //lcd_puts(analogRef[0]);
   lcd_puts(" bar");
  if(millis()-previousLCD> 2*scrollInterval){
   lcd_puts("P. Inlet: ");
   //lcd_puts(analogRef[1]);
   lcd_puts(" bar");
   previousLCD = millis();
void debug(){
   if(millis()-previousDebug> debugInterval){
     if(debugServo){
       Serial.print("Servo pos: ");
       Serial.println(pulsWidth);
       Serial.print("Potmeter pos: ");
       Serial.println(analogRef[servoPot]);
       previousDebug = millis();
I think I will use interupt on the pulse in signal, i wil post the code if I get evrything to work…
I think this:
Should be this:
byte bin [] = {B000,B1,B10,B11,B100,B101,B110,B111}; //binary
…maybe :slight_smile:
