Map() analogRead() Problem
Map value problem;
Although the value read is 1023, result is sometimes 11 en sometimes 12 ????
How can than be?
Basic Code (not actual program!):
ValMap = map(analogRead(A0), 0, 1023, 0 , 12);
Serial.print(analogRead(A0), DEC);Serial.println(ValMap, DEC);
Result on screen
1023 - 11
1023 - 11
1023 - 12
1023 - 12
1023 - 11
Making analogRead() first a Value, then putting it into map(), solved the problem!!!, Thank you...
Try this...
int ara0;
ara0 = analogRead(A0);
ValMap = map(ara0, 0, 1023, 0 , 12);
Serial.print(ara0, DEC);Serial.println(ValMap, DEC);
Cees:
Map value problem;
How can than be?
Result on screen
1023 - 11
1023 - 11
1023 - 12
1023 - 12
1023 - 11
Look at the first two lines of the code, let me quote:
You’re making two different measurements on these lines. Try changing it to the following:
int val1=analogRead(A0);
ValMap = map(val1, 0, 1023, 0 , 12);
Serial.print(val1, DEC)
//Basel
Be aware that the map function has serious rounding troubles around the high end.
for (int i=0; i<1024; i++)
  int x = map(i, 0,1023, 0,12) ;
  Serial.print(i);
  Serial.print("\t");
  Serial.println(x);
you might want to use map(i, 0,1024, 0,13) ; to get the results you want.
Thanks :slight_smile:
