Map and write in one step.
Most code for reading an analogue value, mapping and writing to a servo do something like:
mappedvalue = map(analogValue, 0, 1023, 0, 179);
servo1.write(mappedvalue);
Is there any reason why I can't do this in one step such as:
servo1.write(map(analogValue, 0, 1023, 0, 179));
Just seems more compact.
Any comments/warnings?
There is no reason why you cannot do it all on one line.
The reason I would not do it is because I would not be able to print the intermediate values for debugging purposes.
...R
servo1.write(map(analogValue, 0, 1024, 0, 180));
servo1.write(map(analogValue, 0, 1024, 0, 181));
Respect.
Ops sorry about the (lack of) code tags:
for (i = 0; i < all_answers; ++i)
    printf("Many Thanks");
Since both ranges start at 0, why not:servo1.write((analogValue * 180UL) / 1024);
and why not getting rid also of the analogValue and dump the call to analogRead() right in there if you want to write long lines :slight_smile:
it all depends if you need the value later on.
if mappedvalue is a byte and you write
analogValue = analogRead(myPin);
mappedvalue = map(analogValue, 0, 1023, 0, 180); // only 1023 will lead to 180
//mappedvalue = map(analogValue, 0, 1024, 0, 181); // 1019 and above will lead to 180
aServo.write(mappedvalue);
the optimizer will likely keep mappedvalue in a register and not read from memory to call write() on the Servo
