I am making an Airsoft turret I'm using this code that i found online along with some code in Processing,
ATTACHMENT INSTRUCTIONS:
attach x-axis standard servo to digital I/O pin 5
attach y-axis standard servo to digital I/O pin 6
attach firing transistor / relay to digital I/O pin 7 (or servo that pulls trigger... see directions regarding this below)
#include <Servo.h>
Servo pan; // x axis servo
Servo tilt; // y axis servo
//Servo trigger; // trigger servo - if you have a servo pulling the trigger, uncomment this line
int xPosition = 75; // 'home' position
int yPosition = 80; // 'home' position
int fire = 0; // if 1, fire; else, don't fire
char buff[]= "00000000000"; // store incoming serial bytes
int serialCounter = 0; // how many frames scince last serial byte was available
int serialTimeout = 10000; // max number of frames without incoming serial before going back to idle mode
void setup(){
pan.attach(5);
tilt.attach(6);
//trigger.attach(7); // if you have a servo firing your gun, uncomment this line, and delete the next line
pinMode(7, OUTPUT); // firing transistor / relay
if (Serial.available()>0) {
serialCounter = 0;
for (int i=0; i<10; i++) {
buff*=buff[i+1]; // move each serial buffer byte down one space*
buff[10]=Serial.read(); // add new serial byte to end of buffer*
if (buff[10]=='X' && buff[6] == 'F') { // check for indicators*
_ xPosition = (100*(int(buff[7])-48)) + (10*(int(buff[8])-48)) + (int(buff[9])-48); // previous values are coords_ -
if (buff[10]=='Y' && buff[6] == 'X') {*
_ yPosition = (100*(int(buff[7])-48)) + (10*(int(buff[8])-48)) + (int(buff[9])-48);_ -
if (buff[10]=='F' && buff[8] == 'Y') {*
fire = int(buff[9]) - 48;*
pan.write(xPosition); // send instructions to servos*
tilt.write(yPosition);*
if(fire == 1) { // firing - if your gun needs special triggering, such as semi-auto, define that behavior here.*
digitalWrite(7, HIGH);*
//trigger.write(90); // uncomment for firing servo, and delete previous line*
else{*
digitalWrite(7, LOW);*
//trigger.write(110); // same as above*
else{*
serialCounter++; // timeout check (safety feature)*
if(serialCounter > serialTimeout) { // go into idle mode after serial counter timeout*
pan.write(75);*
tilt.write(150);*
//trigger.write(140); // see above directions regarding servos for firing*
serialCounter = serialTimeout+1;*
else{ // if just a momentary pause:*
pan.write(xPosition); // continue with previous actions*
if(fire == 1) {*
//trigger.write(90); // see above directions regarding servos for firing*
digitalWrite(7, HIGH); // firing relay*
else{*
//trigger.write(110); // see above directions regarding servos for firing*
digitalWrite(7, LOW); // firing relay*
But when i used it, I found that the x axis (pan) servo was moving inverse of the direction i wanted it to go. to fix that i added this line of code:
xPosition = map(xPosition, 0, 180, 180, 0);
and the new code was this:
----------------TURRET VERSION 4 CODE V09---------------
Bob Rudolph
For upload onto arduino board
#include <Servo.h>
int serialTimeout = 10000; // max number of frames without incoming serial before going back to idle modeca
void setup(){
- pan.attach(5);*
- tilt.attach(6);*
- //trigger.attach(7); // if you have a servo firing your gun, uncomment this line, and delete the next line*
- pinMode(7, OUTPUT); // firing transistor / relay*
- Serial.begin(9600);*
*void loop() { * - if (Serial.available()>0) {*
- serialCounter = 0;*
- for (int i=0; i<10; i++) { *
_ buff*=buff[i+1]; // move each serial buffer byte down one space*_
* buff[10]=Serial.read(); // add new serial byte to end of buffer*
* if (buff[10]=='X' && buff[6] == 'F') { // check for indicators*
* if (buff[10]=='Y' && buff[6] == 'X') {*
* if (buff[10]=='F' && buff[8] == 'Y') {*
* fire = int(buff[9]) - 48;*
xPosition = map(xPosition, 0, 180, 180, 0); _
* pan.write(xPosition); // send instructions to servos*
* tilt.write(yPosition);*
* if(fire == 1) { // firing - if your gun needs special triggering, such as semi-auto, define that behavior here.*
* digitalWrite(7, HIGH);*
* //trigger.write(90); // uncomment for firing servo, and delete previous line*
* else{*
* digitalWrite(7, LOW);*
* //trigger.write(110); // same as above*
* else{*
* serialCounter++; // timeout check (safety feature)*
* if(serialCounter > serialTimeout) { // go into idle mode after serial counter timeout*
* pan.write(75);*
* tilt.write(150);*
* //trigger.write(140); // see above directions regarding servos for firing*
* serialCounter = serialTimeout+1;*
* else{ // if just a momentary pause:*
* pan.write(xPosition); // continue with previous actions*
* if(fire == 1) {*
* //trigger.write(90); // see above directions regarding servos for firing*
* digitalWrite(7, HIGH); // firing relay*
* else{*
* //trigger.write(110); // see above directions regarding servos for firing*
* digitalWrite(7, LOW); // firing relay*
Although the new code worked, it also added jitter to my x axis.
How can I fix that? Also, is there another way to invert my x axis servo in this code? I'm sorry if this is a very stupid question, but i am very new to the Arduino.
