map function...have to keep invoking it??
Another question for the kind folks here:
say I have something like this:
float read_volts = analogRead (A7);
int volts_value = map (read_volts, 0, 1023, 0, 5);
rest of my program....blah blah....now need to take another reading...
loop {
blah blah
do I have to keep remapping it, or is the code smart enough to figure out to map it, since I already told it to do so say out side some loop?
in other words is the mapping "global" define it once and done? or have to keep remapping each time a reading is taken?
"... do I have to keep remapping it..."
Yes.
loop {
volts_value = map(analogRead(A7), 0, 1023, 0, 5);
Bit of a waste of time passing a float to map.
cyborgcnc:
or is the code smart enough to ...
For future reference, the answer to this question 99% of the time is going to be no.
AWOL:
so what do you suggest, just keep working with the raw float values out of the analog ports?, ie do not bother with the mapping at all?
thanks!
"read_volts = analogRead (A7);" will return an int, not a float. 0 to 1023.
float volts_value;
volts_value = read_volts * 5/1023; // no mapping needed.
cyborgcnc:
What lead you to believe the integer values from an analogRead were float?
