Map function not working
Hey guys! I need to map a potvalue to dmx (witch takes 0 to 255). With this piece of code i try to make a timer for a smokemachine. (thats why the variables have to do with fire)
But my my firetimer is all over the place.
When Pv6 is 255, the firetimer = 0, for some reason.
When PV6 is 0, the firetimer = 0
when PV6 is 55, the firetimer = 4294960818.
can someone help me?
This is the piece of code you’ll need.
   val = analogRead(P6);
   val = map(val, 0, 1023, 0, 255);
   Pv6 = val;
   if(Pv6 < 250 && Pv6 > 10){
    val = Pv6;                              //save tijd bij vorige fire, vergelijk met verwachte tijd ivm pot
    val = map(val, 0, 255, 30000, 600000); //30000 millisec --> 600000 millisecconds
    firetimer = val;
    nxtfire = lastfire + firetimer;
#include <DmxSimple.h>
#define P1 A0
#define P2 A1
#define P3 A2
#define P4 A3
#define P5 A4
#define P6 A5
#define L1 4
#define L2 5
#define R1 6
#define R2 7
int Pv1;
int Pv2;
int Pv3;
int Pv4;
int Pv5;
int Pv6;
int ledState = LOW;
unsigned long firetimer;
unsigned long lastfire;
unsigned long nxtfire;
const long blinkinterval = 1000;
unsigned long previousMillis = 0;
 DmxSimple.usePin(3);
 DmxSimple.maxChannel(11);
DmxSimple.write(1, Pv5);
DmxSimple.write(2, Pv1);
DmxSimple.write(3, Pv2);
DmxSimple.write(4, Pv3);
DmxSimple.write(9, Pv4);
if(Pv6 > 250){
  digitalWrite(R1, HIGH);
  digitalWrite(L1, HIGH);
}else{
  digitalWrite(R1, LOW);
  digitalWrite(L1, LOW);
int time = millis();
if(time >= nxtfire){
  Serial.println("FIRE IN THE HOLE");
  delay(10000);
  lastfire = millis();
ReadValue();
void ReadValue(){ //map all potvalues to dmx values
  int val = analogRead(P1);
   Pv1 = val;
   val = analogRead(P2);
   Pv2 = val;
   val = analogRead(P3);
   Pv3 = val;
   val = analogRead(P4);
   Pv4 = val;
   val = analogRead(P5);
   Pv5 = val;
   Pv6 = val;
    firetimer = val;
  if (currentMillis - previousMillis >= blinkinterval) {
    if (ledState == LOW) {
      ledState = HIGH;
      ledState = LOW;
    digitalWrite(L1, ledState);
  Serial.print("P1: ");
  Serial.println(Pv1);
  Serial.print("P2: ");
  Serial.println(Pv2);
  Serial.print("P3: ");
  Serial.println(Pv3);
  Serial.print("P4: ");
  Serial.println(Pv4);
  Serial.print("P5: ");
  Serial.println(Pv5);
  Serial.print("P6: ");
  Serial.println(Pv6);
  Serial.print("firetimer: ");
  Serial.println(firetimer);
  Serial.print("nxtfire: ");
  Serial.println(nxtfire);
  Serial.print("Millis(): ");
  Serial.println(millis());
val = map(val, 0, 255, 30000, 600000); Which processor/ board are you using?
"val" is an int, and cannot exceed 32767 on an AVR based Arduino.
It’s an Arduino Uno, that declares a lot. I’ll make it an unsigned long I guess?
Or calculate in seconds or desciseconds and then multiply up with a unsigned long.
Also you should never add times...
   firetimer = val;
Only ever subtract...
fireinterval = val;
if (time - lastfire >= fireinterval) {
Why could i not add timers?
There are issues with millis() rollover.
See this discussion
https://www.gammon.com.au/millis
