Map function returning incorrect value
I am trying to create a program to control a variable speed refrigeration compressor based on temperature. The part I am stuck at is on the map function. It should return a value between 0 and 255 but instead 1147 comes out. What is meant to happen is when the temperature is 5 degrees c the compressor is at full speed and when it is at 0 degrees the compressor runs at the slowest speed.
  float tempC = sensors.getTempC(deviceAddress);
  Serial.print("Temp C: ");
  Serial.print(tempC);
  compspeed = map(tempC, 1, 5, 0, 255);
  Serial.print (compspeed);
and here is the output Temp C: 19.06 1147
You tell map that the range of tempC is 0 to 5. Then you give it 19.
Skip the map. You need if conditions to tell it what to do outside of 0-5 degC.
Map doesn't work with floats, here's one idea.
  int dtempC = tempC * 10;
  dtempC = constrain(dtempC,10,50;
  compspeed = map(dtempC, 10, 50, 0, 255);
Also, compressor may not be able to start with too low PWM, think I would start with compspeed = map(dtempC, 10, 50, 64, 255);
You could use floats in map with a little change to the map formula, but your way skips the hassle. Well, I should say you can create a map that does work with floats, as it's a simple formula anyway.
Over my ol' head :confused: but tnx for the tip.
edgemoron: Map doesn't work with floats, here's one idea.
I stuck a frozen ready meal on top of the sensor to test and this worked perfectly! Thanks so much for your help.
Temp C: 3.75 172
