Hey,
for my home automation project (using raspberries, esp32s, node red and mosquitto as mqtt broker to connect several sensors in my garden), I am thinking about an interactive map of my garden to show various sensor states. So I have different sensors throughout my garden and I want to display the location of each sensor on somekind of map. Best would be google map cut out of just my premisses. I have the locations of all sensors as magnitude and longitude.
What would be the best way (framework etc.) to have a map of my premisses with custom pins for each sensor. To get more infos of the sensor I want it to be possible to press on the desired pin and get more infos.
hey,
thanks.
a floorplan is for indoor housing right? I am looking for something geographical for the garden, just like google maps. Well I choose arduino forum as arduino is used for a lot of homeautomation projects. It doesn't necessarily need to be an addon for red node. I was just wondering what kind of framework I should use, so that i can use e.g. google maps and put custom pins on the map and generate additional infos when the pin is pressed.
jacko91:
That sounds like something that would be much easier to implement on a RaspberryPi
My guess is, you will draw your floorplan, or in your case your gardenplan, and place your sensors on there. But that is just guessing. I still think the node red community will be more helpful.
