map to floating point
I would like to print a value read on the analog input(0-1023) as 0-10.00
I can map it to 0-1000:
Serial.print(map(value,0,1023,0,1000),DEC)
but how can i add "." in the string?
Serial.print(map(value,0,1023,0.0,10.00),DEC)
would be perfect
In other words you want the map-function to return a float and not a long? It's not possible with the map-function, but you can write your own.
Here's map() modified to return a float (if I'm lucky - I haven't tried it):
float mapfloat(long x, long in_min, long in_max, long out_min, long out_max)
  return (float)(x - in_min) * (out_max - out_min) / (float)(in_max - in_min) + out_min;
This won't work if he wants to parse in decimal values in the function, i.e. wants to make the range 5.3 to 10.6. I'd just make everything a float.
float mapfloat(float x, float in_min, float in_max, float out_min, float out_max)
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
I'm pretty sure floats take up more memory however, so I'd be careful... Can someone confirm this?
Using either gives the same size on ATMega328P
It would not return the fraction only the whole number without any decimal places
try this:
int value = analogRead(pin);
Serial.print( map(value, 0,1023,0,1000) / 100.0);
