Map value, servo, LCD
I'm having trouble trying to map the value and drive a servo speed controller. I have the LCD displaying a percentage 0-100% to represent the current flowing through the speed controller. The problem is when the LCD displays 100% the speed controller is stop. When the LCD displays 0% the speed controller is wide open. I been playing with this for several hours. The values flipped and i cant seem to figure it out.
 cutSpeedPot = analogRead(cutspeedPin);            // reads the value of the potentiometer (value between 0 and 1023)
 cutSpeed = map(cutSpeedPot, 1023, 0, 180, 0);     // scale it to use it with the servo (value between 0 and 180)
 cutSpeedLCD = map(cutSpeedPot, 1023, 0, 100, 0);
What do you get if you use Serial.println(100 - cutSpeedLCD) ?
or
What do you get if you reverse the last 2 parameters of map() ?
