Map voltage value with two range
Hi
I don't know if i'm in the good section for my question, i apologize in advance if not.
I created a midi pedal with an expression pedal. So i convert the analog signal from analog 1 (10K pot) to midi value.
The pedal is used to control a fader of a O2R digital mixer, and i would like for example to map 0-500 (voltage) to 0 -40 (MIDI) and 501-1023 to 41-127 to be more precise and the end of the fader range. The pot is linear and it's not practical/convenient for the mix.
Is there someone who know if it possible to do something like that.
Thanks
http://playground.arduino.cc/Main/MultiMap
Is this what you seek?
I will read many times, cause i m not sure i really understand the reMap thing
Of course:
if(val < 500)
   val = map(val, 0, 500, 0, 40);
   val = map(val, 501, 1023, 41, 127);
i tried that but it’s not sucessfull
there is my code
//#define DEBUG
const int THRESHOLD = 7;
const int PINONE =0;;
const int PINTWO =1;
   Serial.begin(31250); 	// Starts communication with the serial port
void loop(){
  PedalPot0();
  PedalPot1();
void PedalPot0 ()
   static int LastPot0Value = 0;
   static int LastMapped0Value = 0;
   int CurrentPot0 = analogRead(PINONE);
   if(abs(CurrentPot0 - LastPot0Value) < THRESHOLD)
     return;
    LastPot0Value = CurrentPot0;
    int Mapped0Value = map(CurrentPot0, 0, 1023, 0, 106); // Map the value to 0-127
    if(Mapped0Value == LastMapped0Value)
      return;
    LastMapped0Value = Mapped0Value;
Serial.println(CurrentPot0);
    VolumePedal0(Mapped0Value);
 void VolumePedal0(byte volume0)
    Serial.write(0xB0);    // Control change command
    Serial.write(0x0A);                       // Volume command
    Serial.write(volume0);              // Volume 0-127
 void PedalPot1 ()
   static int LastPot1Value = 0;
   static int LastMapped1Value = 0;
   int CurrentPot1 = analogRead(PINTWO);
   if(abs(CurrentPot1 - LastPot1Value) < THRESHOLD)
     return;
    LastPot1Value = CurrentPot1;
    int Mapped1Value = map(CurrentPot1, 0, 1023, 0, 106); // Map the value to 0-127
    if(Mapped1Value == LastMapped1Value)
      return;
    LastMapped1Value = Mapped1Value;
    VolumePedal1(Mapped1Value);
 void VolumePedal1(byte volume1)
    Serial.write(0x0C);                       // Volume command
    Serial.write(volume1);              // Volume 0-127
there is my code
Which does not do what I suggested.
i tried that but it's not sucessfull
Doesn't look to me like you tried it, but the code you posted does something. You didn't say what. You want it to do something, but you didn't say what. How can we help you, with so little info to go on?
yeah i posted my first code, but i found my error in the code you give me.
There is my new code who is working great now :
//#define DEBUG
  PedalPot0();
  PedalPot1();
void PedalPot0 ()
   static int Mapped0Value = 0;
     return;
       if ( CurrentPot0 < 300 )
    Mapped0Value = map(CurrentPot0, 0, 250, 0, 45);
    Mapped0Value = map(CurrentPot0, 251, 1023, 46, 106);
      return;
    Serial.write(0xB0);    // Channel
void PedalPot1 ()
   static int Mapped1Value = 0;
     return;
   if ( CurrentPot1 < 300 )
    Mapped1Value = map(CurrentPot1, 0, 250, 0, 45);
    Mapped1Value = map(CurrentPot1, 251, 1023, 46, 106);
      return;
Thanks
