I'm using the following code for getting real-time location using GPS module on arduino cloud but the location is not realtime. The ESP32 has to be reset to get the location.
I'm using some other sensors too, So I've tried multitasking approach as shown in code
// TridentTD_EasyFreeRTOS32 - Version: Latest
// FreeRTOS - Version: Latest
Sketch generated by the Arduino IoT Cloud Thing "Untitled"
https://create.arduino.cc/cloud/things/adce9b5f-8b55-4f05-8c9b-a92bc44c94d2
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
String dig;
int rftar;
CloudLocation loc;
bool btn;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
#include "thingProperties.h"
#include <Wire.h>
#include <TinyGPSPlus.h>
#define DUTY 50
float LAT;
float LONG;
int spd;
int bzr = 2;
const byte pushbtn = 5;
long previousTime = 0;
bool buttonState = 0,
lastButtonState = 1,
pressed = 0;
//bool btn;
TinyGPSPlus gps;
//unsigned int move_index; // moving index, to be used later
unsigned int move_index = 1; // fixed location for now
const int MPU_addr = 0x68; // I2C address of the MPU-6050
int16_t AcX, AcY, AcZ, Tmp, GyX, GyY, GyZ;
float ax = 0, ay = 0, az = 0, gx = 0, gy = 0, gz = 0;
boolean fall = false; //stores if a fall has occurred
boolean trigger1 = false; //stores if first trigger (lower threshold) has occurred
boolean trigger2 = false; //stores if second trigger (upper threshold) has occurred
boolean trigger3 = false; //stores if third trigger (orientation change) has occurred
byte trigger1count = 0; //stores the counts past since trigger 1 was set true
byte trigger2count = 0; //stores the counts past since trigger 2 was set true
byte trigger3count = 0; //stores the counts past since trigger 3 was set true
int angleChange = 0;
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_WROVER_BOARD
//#define USE_TTGO_T7
// Initialize serial and wait for port to open:
Serial2.begin(9600);
pinMode(bzr, OUTPUT);
pinMode(pushbtn, INPUT_PULLUP);
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
Wire.begin();
Wire.beginTransmission(MPU_addr);
Wire.write(0x6B); // PWR_MGMT_1 register
Wire.write(0); // set to zero (wakes up the MPU-6050)
Wire.endTransmission(true);
xTaskCreate(
FELL,
"pehla task",
10000,
NULL,
1,
NULL
xTaskCreate(
WEAR,
"2ra task",
10000,
NULL,
1,
NULL
xTaskCreate(
LOCAT,
"3ra task",
100000,
NULL,
1,
NULL
// Defined in thingProperties.h
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update();
// Your code here
void mpu_read() {
Wire.write(0x3B); // starting with register 0x3B (ACCEL_XOUT_H)
Wire.endTransmission(false);
Wire.requestFrom(MPU_addr, 14, true); // request a total of 14 registers
AcX = Wire.read() << 8 | Wire.read(); // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
AcY = Wire.read() << 8 | Wire.read(); // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
AcZ = Wire.read() << 8 | Wire.read(); // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
Tmp = Wire.read() << 8 | Wire.read(); // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
GyX = Wire.read() << 8 | Wire.read(); // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
GyY = Wire.read() << 8 | Wire.read(); // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
GyZ = Wire.read() << 8 | Wire.read(); // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
void onDigChange() {
// Add your code here to act upon Dig change
//code for function 1
mpu_read();
ax = (AcX - 2050) / 16384.00;
ay = (AcY - 77) / 16384.00;
az = (AcZ - 1947) / 16384.00;
gx = (GyX + 270) / 131.07;
gy = (GyY - 351) / 131.07;
gz = (GyZ + 136) / 131.07;
// calculating Amplitute vactor for 3 axis
float Raw_Amp = pow(pow(ax, 2) + pow(ay, 2) + pow(az, 2), 0.5);
int Amp = Raw_Amp * 10; // Mulitiplied by 10 bcz values are between 0 to 1
Serial.println(Amp);
if (Amp <= 2 && trigger2 == false) { //if AM breaks lower threshold (0.4g)
trigger1 = true;
Serial.println("TRIGGER 1 ACTIVATED");
if (trigger1 == true) {
trigger1count++;
if (Amp >= 12) { //if AM breaks upper threshold (3g)
trigger2 = true;
Serial.println("TRIGGER 2 ACTIVATED");
trigger1 = false; trigger1count = 0;
if (trigger2 == true) {
trigger2count++;
angleChange = pow(pow(gx, 2) + pow(gy, 2) + pow(gz, 2), 0.5); Serial.println(angleChange);
if (angleChange >= 30 && angleChange <= 400) { //if orientation changes by between 80-100 degrees
trigger3 = true; trigger2 = false; trigger2count = 0;
Serial.println("TRIGGER 3 ACTIVATED");
if (trigger3 == true) {
trigger3count++;
if (trigger3count >= 10) {
//delay(10);
if ((angleChange >= 0) && (angleChange <= 10)) { //if orientation changes remains between 0-10 degrees
fall = true; trigger3 = false; trigger3count = 0;
else { //user regained normal orientation
Serial.println("TRIGGER 3 DEACTIVATED");
if (fall == true) { //in event of a fall detection
Serial.println("FALL DETECTED");
digitalWrite(bzr,HIGH);
dig = "Rider fell"; //STRING
delay (1000);
fall = false;
digitalWrite(bzr,LOW);
if (trigger2count >= 6) { //allow 0.5s for orientation change
Serial.println("TRIGGER 2 DECACTIVATED");
if (trigger1count >= 6) { //allow 0.5s for AM to break upper threshold
Serial.println("TRIGGER 1 DECACTIVATED");
void onBtnChange() {
// Add your code here to act upon Btn change
//code for function 2
if(millis() - previousTime >= DUTY){
buttonState = digitalRead(pushbtn);
if(buttonState != lastButtonState){
if(buttonState == 0){
Serial.println("HELMET ON\n");
btn = true;
}else{
Serial.println("HELMET OFF\n");
btn = false;
pressed = 0;
lastButtonState = buttonState;
previousTime = millis();
void onRftarChange() {
//updateSerial();
while (Serial2.available() > 0)
if (gps.encode(Serial2.read()))
displayInfo();
if (millis() > 5000 && gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
while (true);
rftar = spd;
loc = {LAT,LONG};
Serial.println( );
void displayInfo()
if (gps.location.isValid()) {
dig = PropertyActions::CLEAR;
LAT = (gps.location.lat()); //Storing the Lat. and Lon.
LONG = (gps.location.lng());
Serial.print("LAT: ");
Serial.println(LAT, 6); // float to x decimal places
Serial.print("LONG: ");
Serial.println(LONG, 6);
spd = gps.speed.kmph(); //get speed
Serial.print("speed (kmph): ");
Serial.println(spd);
//Serial.print("lost");
dig = "gps signals lost";
/*******************TASKS************************/
void FELL(void*parameters) {
for(;;){
onDigChange();
Serial.println( );
vTaskDelay(1000/portTICK_PERIOD_MS);
/*-------------------TASK BTN------------------------*/
void WEAR(void*parameters) {
for(;;){
onBtnChange();
Serial.println( );
/*------------------TASK SPD/LOCATION-------------------------*/
void LOCAT(void*parameters){
// Add your code here to act upon Rftar change
for(;;){
displayInfo();
while (true);
Serial.println( );
vTaskDelay(1000 / portTICK_PERIOD_MS);
