Mapping AVR 2313 pins to the pins in arduino programming...??
Hello All
I am working with an ATtiny2313 and am wondering how do I map the physical pin on the chip to the pin I am referring to in my program.
Assistance would be much appreciated.
Cheers
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1236434254/52
[edit]Removed Incorrect Table[/edit]
That list of 20 can't be right - the ATTiny2313 only has 20 pins, and two are power & ground.
CrossRoads: That list of 20 can't be right - the ATTiny2313 only has 20 pins, and two are power & ground.
Thought it was too easy to find that table :D
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1265712380
Maybe that could help
Still struggling, so if anyone has any pointers that would be usefull.
I have found the following link which gives a limited mapping (sumarised below) which I will verify tonight, but there are still many pins missing.
| Arduino | Attiny2313 | | - | - | | Pin 10 | Pin 1 - RST | | Pin 11 | Pin 17 - MOSI | | Pin 12 | Pin 18 - MISO | | Pin 13 | Pin 19 - SCK | | Vcc (+5V) | Pin 20 - Vcc | | Gnd | Pin 10 - GND |
It would be great if someone could provide the full mapping list as I do not wish to spend time identifying these - There is loads of other stuff I need to do.
You need to find a file like this two
pins…
for the 2313, or create them.
And probably add to the two .txt files to call out the 2313.
http://www.atmel.com/dyn/resources/prod_documents/doc2543.pdf
If you don’t come across something else, and you are using the Reset lines and an externa Crystal, I would propose this mapping:
Pin1 - Reset, or PA2 (or, D17?)
Pin2 - PD0/RX -->D0
Pin3 - PD1/TX → D1
Pin4 - Crystal, or PA1 (or, D16)
Pin5 - Crystal, or PA0 (or, D15)
Pin6 - PD2/INT0 → D2
Pin7 - PD3/INT1 → D3
Pin8 - PD4 → D4
Pin9 - PD5 → D5
Pin11 - PD6 → D6
Pin12 - PB0/A0 → D7
Pin13 - PB1/A1 → D8
Pin14 - PB2 → D9
Pin15 - PB3 → D10
Pin16 - PB4 → D11
Pin17 - PB5/MOSI/SDA → D12
Pin18 - PB6/MISO → D13
Pin19 - PB7/SCK/SCL → D14
pins_arduino.c (12.1 KB)
pins_arduino.h (3.02 KB)
boards.txt (9.29 KB)
programmers.txt (451 Bytes)
Thanks for the pointers Crossroads
Seems like I need to do a load of 'wiring' to program my 2313 in addition to simply writing the program itself :(
Not really what I want to be doing... but there you go.
http://code.google.com/p/arduino-tiny/ ...has support for the ATtiny2313.
Well that's certainly a lot easier!
Indubitably. :D
Thanks for the help guys
I managed to upload something, but then screwed the device signature.... :(
Anyway, moving forwards slowly. Moved my issue to the micro controllers forum as that seems to fit better.
Cheers
