Mapping robot travel path to txt file
Hi I am trying to implement a code where I take an x and y array and outputs into a simple x and y graph text file. Problem is, the indices I try to call do not match the numbers in the coord array. I have tried several iterations, which are listed below, but have not been able to find a solution. Should I just give up and use python at this point?
Here is one attempt:
#include <SPI.h>
#include <SD.h>
File myFile;
char myArray[10][4]; //output array
int coord[2][10] = {
{0, 1, 2, 3, 3, 4, 5, 5, 5, 5}, //x axis
{0, 0, 1, 1, 2, 2, 2, 3, 4, 5} //y axis
  // SD card check
  Serial.print("Initializing SD card...");
  if (!SD.begin(10))
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
 //Outputs an array with the blank places as . and occupied places as #
for(int x = 0; x < 10; x++){     //x axis
  for(int y = 0; y < 10; y++){   //y axis
    myArray[x][y]='.';
    if (x=y)
    //Serial.print(coord[x][y]); //For debugging purposes
    myArray[(coord[0][x])][(coord[1][y])] ='#';
    Serial.print(myArray[x][y]);
/*myFile = SD.open("map.txt", FILE_WRITE);
if (myFile)
  myFile.print(
  for (int i=10; i>0; i--)    //i equals whatever the length of the array is
   for(int i = 0; i < coord[1][10]; i--){
    for(int j = 0; j < coord[2][10]; j--){
      myFile.print(i)
myFile.close();
  Serial.println("Error opening map.txt");
  // nothing happens after setup
Here is another attempt:
#include <SPI.h>
#include <SD.h>
File myFile;
{0, 0, 1, 1, 2, 2, 2, 3, 4,5} //y axis
  // SD card check
  if (!SD.begin(10))
    while (1);
    myArray[x][y]='.';
    if ((coord[0][x]==x)&&(coord[1][y]==y))
    myArray[x][y] ='#';
if (myFile)
  myFile.print(
      myFile.print(i)
myFile.close();
Finally, I also tried three for loops, but that did not work so well.
    myArray[x][y]='.';
If you are used to interpreted languages, one of the hardest things to grasp about C is that it won’t complain about writing to non-existent array locations
You have to remember not to do that.
      if (x = y)
BONG !
If you break it down a bit is this the result your looking for?
char myArray[10][10]; //output array
int coord[2][10] =
      myArray[x][y]='.';
  for(int z = 0; z < 10; z++){     //array axis
    myArray[coord[0][z]][coord[1][z]] ='#';
That is exactly what I am looking for. Thanks for all your help! Riva, would you happen to know how to invert the matrix so that 5 goes to the front and 1 goes to back and so on. I just want to invert the # and . map.
Riva:
int coord[2][10] =
      myArray[y]=’.’;
    myArray[coord[0][z]][coord[1][z]] =’#’;
      Serial.print(myArray[y]);
My next problem is that I am trying to invert and flip the map so that (0,0) is on the bottom left side. Here is what I’ve tried, and it makes logical sense in my mind, but I can’t get it to work on the serial monitor.
int coord[2][10] = //sample array, it will be a fixed array in the actual code!
  for (int y = 0; y < 10; y++) {   //y axis
    for (int x = 0; x < 10; x++) { //x axis
      myArray[x][y] = '.';
  for (int z = 0; z < 10; z++) {   //array axis
    myArray[(5-coord[0][z])][(5-coord[1][z])] = '#'; //invert matrix, 5=largest number in coord array
    for (int x = 10; x > 0; x--) { //x axis (returns funny map?)
I’m not able to test this but maybe the below code? I have only flipped the x axis for now but doing the y axis instead/as well is just the same.
  for(int x = 9; x >= 0; x--){     //x axis
From reply 5for (int x = 10;
Neither axis has an element with the subscript 10.
