Mapping voltages from analog pin using port manipulation
Hello,
I am new to Arduino. I have learned how to map analog inputs to digital pins, but now I want to use a 4067 16 channel demultiplexer. I have been looking at the code below from this tutorial:
This incrementally writes 000-1111 across digital pins 4-7. How could I use a potentiometer on analog pin 1 and map the voltages to do the same thing?
// 74HC4067 demultiplexer demonstration (1 to 16)
// control pins output table in array form
// see truth table on page 2 of TI 74HC4067 data sheet
// connect 74HC4067 S0~S3 to Arduino D7~D4 respectively
// 5V to 74HC4067 pin 1 to power the LEDs :)
byte controlPins[] = {B00000000,
                      B10000000,
                      B01000000,
                      B11000000,
                      B00100000,
                      B10100000,
                      B01100000,
                      B11100000,
                      B00010000,
                      B10010000,
                      B01010000,
                      B11010000,
                      B00110000,
                      B10110000,
                      B01110000,
                      B11110000 };
  DDRD = B11111111; // set PORTD (digital 7~0) to outputs
void setPin(int outputPin)
// function to select pin on 74HC4067
  PORTD = controlPins[outputPin];
  for (int i = 0; i < 16; i++)
    setPin(i);
    delay(250);
  int i = analogRead(A1) / 64;
  setPin(i);
  delay(250);
