mapping/wireless transmitting/lcd help
I'm having difficulties trying to transmit battery voltage measurement data. I've created an external voltage divider in order to create the necessary 5V max for an analog input. I want to transmit this data to another Arduino board (via XBEE) to create a remote battery monitor. Below is the code I have right now (not all of it, but the parts that pertain to this problem. the transmitter code:
int B_Volt = 3;
byte batVolt;
  Serial.begin(19200);
  batVolt = map(analogRead(B_Volt), 0, 1023, 0, 245);
  Serial.print(250, BYTE);             // ------------------------SYNC
  Serial.print(batVolt, BYTE);        //battery voltage reading
the code for the receiver:
byte RemBatVolt;
  if (Serial.available() > 0) {
    incoming = Serial.read();
    if (int(incoming) == 250) {
      RemBatVolt = Serial.read();
      RemBatVolt = map(RemBatVolt, 0, 245, 0, 1023);
  lcd.setCursor(0,0);
  lcd.print("Remote Batt.: ");
  lcd.print((int(RemBatVolt) / 83),DEC);
  lcd.print(".");
  lcd.print((int(RemBatVolt) % 83),DEC);
  lcd.print("V");
When I run the code, I know that the value transmitted is 169, but the received value is 28. Any suggestions?
You check for at least one byte, and then read two (if the first is 250). You need to make sure that the second byte has arrived before trying to read it.
Which one? You are sending two values.
Which one? You are receiving two values.
  lcd.print(".");
83? Where did that come from?
Sorry. I tried debugging by printing the value of batVolt (from the transmitter) to another LCD screen, and the value is constantly 169.
Again, sorry for not being clearer. When debugging, I had the receiver print the value of int(RemBatVolt) to the LCD screen, and it is 28.
  lcd.print(".");
I got this idea from http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1199738420. It's a scaling factor used to transform voltages. I know that the battery pack I have can supply up to 12.3V when fully charged. Also, the analog input pins on the Arduino have 1024 values. So I want 1024 to map to 12.3 volts. Therefore: (1024/x)=12.3 ==> x ~83. In the example I got this method from, they had a 10V supply instead of a 12.3V supply.
