Mariamole an improved Editor for arduino
Alex Dalpix made something that might interest you >> http://dalpix.com/mariamole
downloaded it and my Zone-Alarm (firewall) tilted because Maria Mole wanted to connect to the internet. Why?
I refused and continued.
Pointed it to my 0.22 Arduino installation and wanted to open an new project based upon Basic/analogRead and an error popped up because it combined the extension .pde and .ino [translation: the system cannot find the file]
So immediately two strange things ==> so some work to do .
install and un-install worked very well by the way.
Hello, robtillaart
It uses the Internet connection for the same reason the original Arduino IDE uses: To check for a new version, solely.
But I understand the problem with PDE and INO. It's not compatible with previous versions of Arduino, just 1.0 or newer.
The program/documentation should be very specific in describing that, then. I don’t allow programs random access to the internet.
I've been using it for a few hours, still can't get a download but we're (Alex and I) hopefully working that out.
I quite like it, the tool bar is a little 1990s (but then so is the official IDE) I feel but overall so far so good.
BTW, I commented about the name here
http://arduino.cc/forum/index.php?topic=134889.new;topicseen#new
Rob
Its a pity It does not support older versions too (I have some code in maintenance I do not want to port to 1.xx)
rob
off topic may be.
but for my info, why would you not move some code up ?
i understod the newer version fixed bugs in the old .
ta
I see that you have shortcut keys, but where is the list?
Graynomad: I've been using it for a few hours, still can't get a download but we're (Alex and I) hopefully working that out.
I like it too, it's exactly what I need. AVR studio is a bit too much, and Arduino IDE lacks several features.
However, like Rob, I can't upload to the arduino. Compilation works.
@DrJohn Smith
rob
off topic may be. but for my info, why would you not move some code up ? i understod the newer version fixed bugs in the old .
ta
Several reasons no to upgrade I used in the past. - upgrading might introduce new issues as behaviour changed in some libraries e.g. Hardware serial flush(), timing of loop() - upgrading costs me more time than maintaining - the size of some libraries have grown, this might be critical for some big sketches - don't know for sure, not eager to find out ;) - Current version of the sketches are stable and have no known issues (aka bugs) any more so why upgrade? - The timing e.g. of millis() / delay() differs and all critical tuning in the sketches needs to be adjusted again.
to show the last one.
  Serial.println(millis());
IDE 1.0.3 output
0
999
1999
3000
4000
5000
6000
7001
8001
9001
10002
11001
12002
13002
14003
15003
16004
17004
18003
19004
20004
delta of 4 millis in 20 seconds
IDE 0.22 output
0
999
1999
3001
4001
5002
6002
7003
8004
9005
10005
11005
12007
13007
14008
15009
16010
17011
18012
19012
20014
delta of 14 millis in 20 seconds ( ... 500473 ...600571 ==> almost 1/1000 )
printing 5or 6 digits + CRLF over serial costs between 0.8-1.0 millisecond@115200, so the 0.22 timing is not that bad in timing I guess.. or is the 1.0.3. a bit too fast?
And yes, it is a per sketch choice to upgrade and which platform to choose. And FWIW my latest sketches are almost all based upon 1.0.3 (I should try the 1.0.4 soon)
