I'm trying to compile marlin-2.0.x firmware with RepRapDiscount Full Graphic Smart Controller. But stuck with this error. Both u8glib 1.8 and 1.9
In file included from sketch/src/lcd/dogm/marlinui_DOGM.h:31:0,
from sketch/src/lcd/marlinui.cpp:126:
sketch/src/lcd/dogm/HAL_LCD_class_defines.h: In member function 'void U8GLIB_64128N_2X_HAL::init(pin_t, pin_t, pin_t, pin_t, pin_t)':
sketch/src/lcd/dogm/HAL_LCD_class_defines.h:37:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_st7565_64128n_HAL_2x_sw_spi, (uint8_t)sck, (uint8_t)mosi, (uint8_t)cs, (uint8_t)a0, (uint8_t)reset);
sketch/src/lcd/dogm/HAL_LCD_class_defines.h: In member function 'void U8GLIB_64128N_2X_HAL::init(pin_t, pin_t, pin_t)':
sketch/src/lcd/dogm/HAL_LCD_class_defines.h:40:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_st7565_64128n_HAL_2x_hw_spi, (uint8_t)cs, (uint8_t)a0, (uint8_t)reset);
sketch/src/lcd/dogm/HAL_LCD_class_defines.h: In member function 'void U8GLIB_ST7920_128X64_4X_HAL::init(pin_t, pin_t, pin_t, pin_t)':
sketch/src/lcd/dogm/HAL_LCD_class_defines.h:53:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_st7920_128x64_HAL_4x_sw_spi, (uint8_t)sck, (uint8_t)mosi, (uint8_t)cs, U8G_PIN_NONE, (uint8_t)reset); // a0 = U8G_PIN_NONE
sketch/src/lcd/dogm/HAL_LCD_class_defines.h: In member function 'void U8GLIB_ST7920_128X64_4X_HAL::init(pin_t, pin_t)':
sketch/src/lcd/dogm/HAL_LCD_class_defines.h:56:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_st7920_128x64_HAL_4x_hw_spi, (uint8_t)cs, U8G_PIN_NONE, (uint8_t)reset); // a0 = U8G_PIN_NONE
sketch/src/lcd/dogm/HAL_LCD_class_defines.h: In member function 'void U8GLIB_ST7920_128X64_RRD::init(pin_t, pin_t, pin_t, pin_t)':
sketch/src/lcd/dogm/HAL_LCD_class_defines.h:71:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_st7920_128x64_rrd_sw_spi, (uint8_t)sck, (uint8_t)mosi, (uint8_t)cs, U8G_PIN_NONE, (uint8_t)reset); // a0 = U8G_PIN_NONE
sketch/src/lcd/dogm/HAL_LCD_class_defines.h: In member function 'void U8GLIB_SH1106_128X64_2X_I2C_2_WIRE::init(uint8_t)':
sketch/src/lcd/dogm/HAL_LCD_class_defines.h:81:59: error: 'init' is not a member of 'U8GLIB'
void init(uint8_t options = U8G_I2C_OPT_NONE) { U8GLIB::init(&u8g_dev_sh1106_128x64_2x_i2c_2_wire, options); }
sketch/src/lcd/dogm/HAL_LCD_class_defines.h: In member function 'void U8GLIB_SSD1306_128X64_2X_I2C_2_WIRE::init(uint8_t)':
sketch/src/lcd/dogm/HAL_LCD_class_defines.h:90:59: error: 'init' is not a member of 'U8GLIB'
void init(uint8_t options = U8G_I2C_OPT_NONE) { U8GLIB::init(&u8g_dev_ssd1306_128x64_2x_i2c_2_wire, options); }
sketch/src/lcd/dogm/HAL_LCD_class_defines.h: In member function 'void U8GLIB_TFT_320X240_UPSCALE_FROM_128X64::init(uint8_t, uint8_t, uint8_t)':
sketch/src/lcd/dogm/HAL_LCD_class_defines.h:103:77: error: 'init' is not a member of 'U8GLIB'
void init(uint8_t cs, uint8_t rs, uint8_t reset = U8G_PIN_NONE) { U8GLIB::init(&u8g_dev_tft_320x240_upscale_from_128x64, cs, rs, reset); }
sketch/src/lcd/dogm/HAL_LCD_class_defines.h: In member function 'void U8GLIB_MINI12864_2X_HAL::init(uint8_t, uint8_t, uint8_t, uint8_t, uint8_t)':
sketch/src/lcd/dogm/HAL_LCD_class_defines.h:115:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_uc1701_mini12864_HAL_2x_sw_spi, sck, mosi, cs, a0, reset);
sketch/src/lcd/dogm/HAL_LCD_class_defines.h: In member function 'void U8GLIB_MINI12864_2X_HAL::init(uint8_t, uint8_t, uint8_t)':
sketch/src/lcd/dogm/HAL_LCD_class_defines.h:118:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_uc1701_mini12864_HAL_2x_hw_spi, cs, a0, reset);
sketch/src/lcd/dogm/HAL_LCD_class_defines.h: In member function 'void U8GLIB_SSD1309_128X64_HAL::init(pin_t, pin_t, pin_t, pin_t, pin_t)':
sketch/src/lcd/dogm/HAL_LCD_class_defines.h:131:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_ssd1309_sw_spi, (uint8_t)sck, (uint8_t)mosi, (uint8_t)cs, (uint8_t)a0, (uint8_t)reset);
sketch/src/lcd/dogm/HAL_LCD_class_defines.h: In member function 'void U8GLIB_SSD1309_128X64_HAL::init(pin_t, pin_t, pin_t)':
sketch/src/lcd/dogm/HAL_LCD_class_defines.h:134:13: error: 'init' is not a member of 'U8GLIB'
U8GLIB::init(&u8g_dev_ssd1309_hw_spi, (uint8_t)cs, (uint8_t)a0, (uint8_t)reset);
exit status 1
Error compiling for board Arduino Mega or Mega 2560.
