If you look into this demo-code
you see that there are defined different
server.on()'s
server.on("/", handle_OnConnect);
server.on("/led1on", handle_led1on);
server.on("/led1off", handle_led1off);
server.on("/led2on", handle_led2on);
server.on("/led2off", handle_led2off);
server.onNotFound(handle_NotFound);
If you write such code from scratch you have to write yourself all the fundamentals like
void handle_led1on() {
LED1status = HIGH;
Serial.println("GPIO4 Status: ON");
server.send(200, "text/html", SendHTML(true,LED2status));
and then write yourself the SendHTML-function
String SendHTML(uint8_t led1stat,uint8_t led2stat){
String ptr = "<!DOCTYPE html> <html>\n";
ptr +="<head><meta name=\"viewport\" content=\"width=device-width, initial-scale=1.0, user-scalable=no\">\n";
ptr +="<title>LED Control</title>\n";
ptr +="<style>html { font-family: Helvetica; display: inline-block; margin: 0px auto; text-align: center;}\n";
ptr +="body{margin-top: 50px;} h1 {color: #444444;margin: 50px auto 30px;} h3 {color: #444444;margin-bottom: 50px;}\n";
ptr +=".button {display: block;width: 80px;background-color: #3498db;border: none;color: white;padding: 13px 30px;text-decoration: none;font-size: 25px;margin: 0px auto 35px;cursor: pointer;border-radius: 4px;}\n";
ptr +=".button-on {background-color: #3498db;}\n";
ptr +=".button-on:active {background-color: #2980b9;}\n";
ptr +=".button-off {background-color: #34495e;}\n";
ptr +=".button-off:active {background-color: #2c3e50;}\n";
ptr +="p {font-size: 14px;color: #888;margin-bottom: 10px;}\n";
ptr +="</style>\n";
ptr +="</head>\n";
ptr +="<body>\n";
ptr +="<h1>ESP32 Web Server</h1>\n";
ptr +="<h3>Using Access Point(AP) Mode</h3>\n";
if(led1stat)
{ptr +="<p>LED1 Status: ON</p><a class=\"button button-off\" href=\"/led1off\">OFF</a>\n";}
{ptr +="<p>LED1 Status: OFF</p><a class=\"button button-on\" href=\"/led1on\">ON</a>\n";}
if(led2stat)
{ptr +="<p>LED2 Status: ON</p><a class=\"button button-off\" href=\"/led2off\">OFF</a>\n";}
{ptr +="<p>LED2 Status: OFF</p><a class=\"button button-on\" href=\"/led2on\">ON</a>\n";}
ptr +="</body>\n";
ptr +="</html>\n";
return ptr;
Which means you have to learn HTML in addition to server-handling
If you do this you have full control about all details but it needs to know all the html-details.
This is the reason why I prefer to use a library for the Web-GUI.
Using such a library eliminates the need to learn html for the price that the design is only partially modifiable
for example ESPUI or ESP-Dash
Here is a demo for ESPUI
#include <DNSServer.h>
#include <ESPUI.h>
const byte DNS_PORT = 53;
IPAddress apIP(192, 168, 4, 1);
DNSServer dnsServer;
#if defined(ESP32)
#include <WiFi.h>
#else
#include <ESP8266WiFi.h>
#endif
const char* ssid = "ESPUI";
const char* password = "espui";
const char* hostname = "espui";
uint16_t button1;
uint16_t switchOne;
uint16_t status;
void numberCall(Control* sender, int type)
Serial.println(sender->value);
void textCall(Control* sender, int type)
Serial.print("Text: ID: ");
Serial.print(sender->id);
Serial.print(", Value: ");
void slider(Control* sender, int type)
Serial.print("Slider: ID: ");
void buttonCallback(Control* sender, int type)
switch (type)
case B_DOWN:
Serial.println("Button DOWN");
case B_UP:
Serial.println("Button UP");
void buttonExample(Control* sender, int type)
switch (type)
case B_DOWN:
Serial.println("Status: Start");
ESPUI.updateControlValue(status, "Start");
ESPUI.getControl(button1)->color = ControlColor::Carrot;
ESPUI.updateControl(button1);
case B_UP:
Serial.println("Status: Stop");
ESPUI.updateControlValue(status, "Stop");
ESPUI.getControl(button1)->color = ControlColor::Peterriver;
void padExample(Control* sender, int value)
switch (value)
case P_LEFT_DOWN:
Serial.print("left down");
case P_LEFT_UP:
Serial.print("left up");
case P_RIGHT_DOWN:
Serial.print("right down");
case P_RIGHT_UP:
Serial.print("right up");
case P_FOR_DOWN:
Serial.print("for down");
case P_FOR_UP:
Serial.print("for up");
case P_BACK_DOWN:
Serial.print("back down");
case P_BACK_UP:
Serial.print("back up");
case P_CENTER_DOWN:
Serial.print("center down");
case P_CENTER_UP:
Serial.print("center up");
Serial.print(" ");
Serial.println(sender->id);
void switchExample(Control* sender, int value)
switch (value)
case S_ACTIVE:
Serial.print("Active:");
case S_INACTIVE:
Serial.print("Inactive");
Serial.print(" ");
void selectExample(Control* sender, int value)
Serial.print("Select: ID: ");
void otherSwitchExample(Control* sender, int value)
switch (value)
case S_ACTIVE:
case S_INACTIVE:
Serial.print(" ");
void setup(void)
#if defined(ESP32)
WiFi.setHostname(hostname);
#else
WiFi.hostname(hostname);
#endif
// try to connect to existing network
WiFi.begin(ssid, password);
Serial.print("\n\nTry to connect to existing network");
uint8_t timeout = 10;
// Wait for connection, 5s timeout
do
Serial.print(".");
timeout--;
} while (timeout && WiFi.status() != WL_CONNECTED);
// not connected -> create hotspot
if (WiFi.status() != WL_CONNECTED)
Serial.print("\n\nCreating hotspot");
WiFi.mode(WIFI_AP);
delay(100);
WiFi.softAPConfig(apIP, apIP, IPAddress(255, 255, 255, 0));
#if defined(ESP32)
uint32_t chipid = 0;
for (int i = 0; i < 17; i = i + 8)
chipid |= ((ESP.getEfuseMac() >> (40 - i)) & 0xff) << i;
#else
uint32_t chipid = ESP.getChipId();
#endif
char ap_ssid[25];
snprintf(ap_ssid, 26, "ESPUI-%08X", chipid);
WiFi.softAP(ap_ssid);
timeout = 5;
do
Serial.print(".");
timeout--;
} while (timeout);
dnsServer.start(DNS_PORT, "*", apIP);
Serial.println("\n\nWiFi parameters:");
Serial.print("Mode: ");
Serial.println(WiFi.getMode() == WIFI_AP ? "Station" : "Client");
Serial.print("IP address: ");
Serial.println(WiFi.getMode() == WIFI_AP ? WiFi.softAPIP() : WiFi.localIP());
uint16_t tab1 = ESPUI.addControl(ControlType::Tab, "Settings 1", "Settings 1");
uint16_t tab2 = ESPUI.addControl(ControlType::Tab, "Settings 2", "Settings 2");
uint16_t tab3 = ESPUI.addControl(ControlType::Tab, "Settings 3", "Settings 3");
// shown above all tabs
status = ESPUI.addControl(ControlType::Label, "Status:", "Stop", ControlColor::Turquoise);
uint16_t select1
= ESPUI.addControl(ControlType::Select, "Select:", "", ControlColor::Alizarin, tab1, &selectExample);
ESPUI.addControl(ControlType::Option, "Option1", "Opt1", ControlColor::Alizarin, select1);
ESPUI.addControl(ControlType::Option, "Option2", "Opt2", ControlColor::Alizarin, select1);
ESPUI.addControl(ControlType::Option, "Option3", "Opt3", ControlColor::Alizarin, select1);
ESPUI.addControl(ControlType::Text, "Text Test:", "a Text Field", ControlColor::Alizarin, tab1, &textCall);
// tabbed controls
ESPUI.addControl(ControlType::Label, "Millis:", "0", ControlColor::Emerald, tab1);
button1 = ESPUI.addControl(
ControlType::Button, "Push Button", "Press", ControlColor::Peterriver, tab1, &buttonCallback);
ESPUI.addControl(ControlType::Button, "Other Button", "Press", ControlColor::Wetasphalt, tab1, &buttonExample);
ESPUI.addControl(ControlType::PadWithCenter, "Pad with center", "", ControlColor::Sunflower, tab2, &padExample);
ESPUI.addControl(ControlType::Pad, "Pad without center", "", ControlColor::Carrot, tab3, &padExample);
switchOne = ESPUI.addControl(ControlType::Switcher, "Switch one", "", ControlColor::Alizarin, tab3, &switchExample);
ESPUI.addControl(ControlType::Switcher, "Switch two", "", ControlColor::None, tab3, &otherSwitchExample);
ESPUI.addControl(ControlType::Slider, "Slider one", "30", ControlColor::Alizarin, tab1, &slider);
ESPUI.addControl(ControlType::Slider, "Slider two", "100", ControlColor::Alizarin, tab3, &slider);
ESPUI.addControl(ControlType::Number, "Number:", "50", ControlColor::Alizarin, tab3, &numberCall);
* .begin loads and serves all files from PROGMEM directly.
* If you want to serve the files from LITTLEFS use ESPUI.beginLITTLEFS
* (.prepareFileSystem has to be run in an empty sketch before)
// Enable this option if you want sliders to be continuous (update during move) and not discrete (update on stop)
// ESPUI.sliderContinuous = true;
* Optionally you can use HTTP BasicAuth. Keep in mind that this is NOT a
* SECURE way of limiting access.
* Anyone who is able to sniff traffic will be able to intercept your password
* since it is transmitted in cleartext. Just add a string as username and
* password, for example begin("ESPUI Control", "username", "password")
ESPUI.begin("ESPUI Control");
void loop(void)
dnsServer.processNextRequest();
static long oldTime = 0;
static bool switchi = false;
if (millis() - oldTime > 5000)
switchi = !switchi;
ESPUI.updateControlValue(switchOne, switchi ? "1" : "0");
oldTime = millis();
here is a ESP-Dash-Demo
#include <Arduino.h>
#if defined(ESP8266)
/* ESP8266 Dependencies */
#include <ESPAsyncTCP.h>
#include <ESPAsyncWebServer.h> //
/* on ESP8266 LED is connected to Vdd => HIGH = LED off */
#define LEDStateOff HIGH
#elif defined(ESP32)
/* ESP32 Dependencies */
#include <WiFi.h>
#include <AsyncTCP.h> // https://github.com/me-no-dev/AsyncTCP
#include <ESPAsyncWebServer.h> // https://github.com/me-no-dev/ESPAsyncWebServer
#define LEDStateOff LOW
#endif
#include <AsyncElegantOTA.h> // manual https://randomnerdtutorials.com/esp32-ota-over-the-air-arduino/
// https://github.com/ayushsharma82/AsyncElegantOTA
#include <ESPDash.h> // https://github.com/ayushsharma82/ESP-DASH
const char *ssid = "";
const char *password = "";
unsigned long MyTestTimer = 0; // variables used with millis() MUST be of type unsigned long
const byte OnBoard_LED = 2;
bool DoBlink = true;
unsigned long BlinkFreq = 500;
int Slider2Pos = 5;
AsyncWebServer MyServer(80);
ESPDash MyDashboard(&MyServer);
// Button Card Format - (Dashboard Instance, Card Type, descriptive Text)
Card MyButton(&MyDashboard, BUTTON_CARD, "Blink On / Off");
// Slider Card Format - (Dashboard Instance, Card Type, descriptive Text, Card Symbol(optional), int min, int max)
Card MySlider1(&MyDashboard, SLIDER_CARD, "Blink-Period in Milliseconds", "", 50, 1000);
Card MySlider2(&MyDashboard, SLIDER_CARD, "2ndSlider", "Testtext", 0, 10);
void PrintFileNameDateTime() {
Serial.println("Code running comes from file ");
Serial.println(__FILE__);
Serial.print(" compiled ");
Serial.print(__DATE__);
Serial.print(" ");
Serial.println(__TIME__);
boolean TimePeriodIsOver (unsigned long &expireTime, unsigned long TimePeriod) {
if ( currentMillis - expireTime >= TimePeriod )
expireTime = currentMillis; // set new expireTime
return true; // more time than TimePeriod) has elapsed since last time if-condition was true
else return false; // not expired
void BlinkHeartBeatLED(int IO_Pin, int BlinkPeriod) {
static unsigned long MyBlinkTimer;
pinMode(IO_Pin, OUTPUT);
if ( TimePeriodIsOver(MyBlinkTimer,BlinkPeriod) ) {
digitalWrite(IO_Pin,!digitalRead(IO_Pin) );
void setup(){
delay(200);
Serial.println("Setup-Start");
PrintFileNameDateTime();
pinMode(OnBoard_LED, OUTPUT);
digitalWrite(OnBoard_LED, LOW);
Serial.print("Trying to connect to WiFi..");
Serial.print(ssid);
Serial.print(".");
Serial.print("connected \r\n type this IP-Adress into your browser ");
Serial.println(WiFi.localIP() );
Serial.println("to see the ESP-Dash-Board");
// Attach Button Callback this function gets executed every time the Button is clicked
MyButton.attachCallback([&](bool MyButtonState){
DoBlink = MyButtonState;
Serial.println("Button Triggered: " + String((MyButtonState)?"true":"false"));
MyButton.update(MyButtonState); //Make sure we update our button's value and send update to dashboard */
MyDashboard.sendUpdates();
// Attach Slider Callback this function gets executed every time the slider is adjusted to a new value
MySlider1.attachCallback([&](int MySliderValue){
BlinkFreq = MySliderValue;
Serial.println("MySlider1 Triggered: " + String(MySliderValue));
MySlider1.update(MySliderValue); // Make sure we update our slider's value and send update to dashboard */
MySlider2.attachCallback([&](int MySliderValue){
Serial.println("slider2 Triggered: " + String(MySliderValue));
Slider2Pos = MySliderValue;
MySlider2.update(MySliderValue);
AsyncElegantOTA.begin(&MyServer); // Start ElegantOTA
MyServer.begin(); // Start server
MyButton.update(DoBlink);
MySlider1.update( int(500) );
AsyncElegantOTA.loop(); // this line enables the OTA-updating
if (DoBlink) {
BlinkHeartBeatLED(OnBoard_LED,BlinkFreq / 2); // half and half On/Off
else {
digitalWrite(OnBoard_LED,LEDStateOff);
if ( TimePeriodIsOver(MyTestTimer,1000) ) {
Slider2Pos++;
if (Slider2Pos > 10) {
Slider2Pos = 0;
MySlider2.update( int(Slider2Pos) ); // your code can change the sliders value too
If you look through the the two code-examples you see that all the html-stuff is "under the hood"
and managed for you in the background. Displaying data, reacting on button-clicks on the website is done in pure C++
best regards Stefan
