Hello,
New to these forums. I'm working on a huge project with over 600m of digital LED strips from Adafruit. I'm using an ultrasonic sensor to make an initial lighting state change and then capacitive touch sensor to trigger subsequent state changes.
See below for my current code. Here are my issues with the behavior:
- When passing in front of ultrasonic sensor - Strip1 lights up then Strip2 with brighter light as expected - but in sequence [need these to happen simultaneously]
- When moving away from the ultrasonic sensor - strip1 dims immediately then Strip2 [need these to happen simultaneously]
- Strip1 (connected to pins 2,3) - lights up as expected when touching capacitive button
- Strip2 (connected to pins 4,5) - lights up as expected when touching capacitive button
- Both touch sensors are really slow to respond (you have to hold them for 2-3secs) - sometimes they are instant - but often it takes way too long for the color change state
My biggest issues are the staged lighting as a result of the ultrasonic sensor & the slow button responses.
Side question - what if I need to monitor multiple (say 4) ultrasonic sensor simultaneously so that if there is motion on any side of the installation.
Thanks for any help anyone can offer!
#include "LPD8806.h"
#include "SPI.h"
// Program to control LPD8806-based RGB LED Modules in multiple strips - multi-tasking button demo
// Number of RGB LEDs in strand:
int nLEDs = 160; //assumes both strands have same number of LEDs
// Chose 2 pins for output; can be any valid output pins:
int dataPin1 = 2;
int clockPin1 = 3;
int dataPin2 = 4;
int clockPin2 = 5;
// First parameter is the number of LEDs in the strand. The LED strips
// are 32 LEDs per meter but you can extend or cut the strip. Next two
// parameters are SPI data and clock pins:
LPD8806 strip1 = LPD8806(nLEDs, dataPin1, clockPin1);
LPD8806 strip2 = LPD8806(nLEDs, dataPin2, clockPin2);
//Setup Sonar variables
int sonarPin = 0; //pin connected to analog out on maxsonar sensor
int inchesAway; //setup holder variable for the sonar reading
//Setup Capacitive Touch Sensor variables
int touchpin1 = 8; //pin connected to capacitive touch sensor 1
int touchstate1 = 0; //setup initial state of touch sensor to off/low
int touchpin2 = 9; //pin connected to capacitive touch sensor 2
int touchstate2 = 0; //setup initial state of touch sensor to off/low
long strip1Start; //setup timing variables
long strip2Start;
boolean strip1On = false; //setup strip state variables
boolean strip2On = false;
// Start up the LED strip
strip1.begin();
strip2.begin();
// Update the strip, to start they are all 'off'
strip1.show();
strip2.show();
//setup the LED strip as the output - DO WE NEED THIS??
//pinMode(LEDpin, OUTPUT);
pinMode(touchpin1, INPUT);
pinMode(touchpin2, INPUT);
//*****Strip1 ON & timing routine*****
if (strip1On) // strip is on now - check if it is time to turn it off
if (millis() - strip1Start > 10000) // if 10000 milliseconds has passed, it is time to turn off
strip1On = false;
else if (digitalRead(touchpin1) == HIGH) // strip is not on yet, check the touch sensor
strip1On = true;
strip1Start = millis(); // set a timer to remember when we turned it on
colorWipeFULL(strip1.Color( 0, 127, 127), 1); // Fill full strip1 with Cyan
else if (analogRead(sonarPin) /2 < 60) // if no touch sensor, check the sonar
colorWipe1st(strip1.Color( 127, 80, 50), 1); // fill with white
colorWipe2nd(strip1.Color( 0, 0, 0), 1); // turn off second half pixels
else //By default - display dim white light
colorWipe1st(strip1.Color( 32, 20, 13), 1); // White - quarter brightness
colorWipe2nd(strip1.Color( 0, 0, 0), 1); // fill with white
//*****Strip2 ON & timing routine*****
if (strip2On) // strip is on now - check if it is time to turn it off
if (millis() - strip2Start > 10000) // if 10000 milliseconds has passed, it is time to turn off
strip2On = false;
else if (digitalRead(touchpin2) == HIGH) // strip is not on yet, check the touch sensor
strip2On = true;
strip2Start = millis(); // set a timer to remember when we turned it on
colorWipeFULL2(strip2.Color( 127, 30, 0), 1); // Fill full strip2 with Orange
colorWipe1st2(strip2.Color( 127, 80, 50), 1); // fill with white
colorWipe2nd2(strip2.Color( 0, 0, 0), 1); // turn off second half pixels
colorWipe1st2(strip2.Color( 32, 20, 13), 1); // White - quarter brightness
///////////////////////Fill Functions - Strip1///////////////
// Fill the dots progressively along a 1st half of the strip.
void colorWipe1st(uint32_t c, uint8_t wait) {
int i;
//strip.numPixels() - use this command below - replace 80 - to have entire strip fill
for (i=0; i < 80; i++) {
strip1.setPixelColor(i, c);
strip1.show();
delay(wait);
// Fill the dots progressively along a 2nd half of the strip.
void colorWipe2nd(uint32_t c, uint8_t wait) {
int i;
for (i=80; i < 160; i++) {
strip1.show();
delay(wait);
// Fill the dots progressively along the ENTIRE strip.
void colorWipeFULL(uint32_t c, uint8_t wait) {
int i;
for (i=0; i < strip1.numPixels(); i++) {
strip1.show();
delay(wait);
///////////////////////STRIP 2 CODE////////////////////////////////
void colorWipe1st2(uint32_t c, uint8_t wait) {
int i;
strip2.setPixelColor(i, c);
strip2.show();
delay(wait);
void colorWipe2nd2(uint32_t c, uint8_t wait) {
int i;
strip2.show();
delay(wait);
void colorWipeFULL2(uint32_t c, uint8_t wait) {
int i;
for (i=0; i < strip2.numPixels(); i++) {
strip2.show();
delay(wait);
