I have for a long time been struggling with uploading anything to my ESP32CAM via Arduino IDE. I have tried using MB board and via FT232RL FTDI USB C to TTL Serial Converter, but without any glimpse of success. I have tried to update misc drivers (CH340 and FT232 driver).
This is the simple code that I try to upload using the FT232RL FTDI USB C to TTL Serial Converter.
pinMode(2, OUTPUT); // Set GPIO 2 as an output for the external LED
digitalWrite(2, HIGH); // Turn the LED on
delay(1000); // Wait for a second
digitalWrite(2, LOW); // Turn the LED off
This is my Arduino Setup:
This is my device manager:
This is the error I get:
Sketch uses 319392 bytes (10%) of program storage space. Maximum is 3145728 bytes.
Global variables use 20148 bytes (6%) of dynamic memory, leaving 307532 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.8.1
Serial port COM4
Connecting......................................
A fatal error occurred: Failed to connect to ESP32: No serial data received.
For troubleshooting steps visit: https://docs.espressif.com/projects/esptool/en/latest/troubleshooting.html
Failed uploading: uploading error: exit status 2
This is some other debug information:
Waiting for gdb server to start...[2025-02-01T09:32:07.661Z] SERVER CONSOLE DEBUG: onBackendConnect: gdb-server session connected. You can switch to "DEBUG CONSOLE" to see GDB interactions.
"C:\\Users\\cfsor\\AppData\\Local\\Arduino15\\packages\\esp32\\tools\\openocd-esp32\\v0.12.0-esp32-20241016/bin/openocd" -c "gdb_port 50000" -c "tcl_port 50001" -c "telnet_port 50002" -s "c:\\Users\\cfsor\\AppData\\Local\\Temp\\.arduinoIDE-unsaved2025028-12656-arf9h.1uuxqa\\Blink" -f "C:/Users/cfsor/AppData/Local/Programs/Arduino IDE/resources/app/plugins/cortex-debug/extension/support/openocd-helpers.tcl" -f board/esp32-wrover-kit-3.3v.cfg
Open On-Chip Debugger v0.12.0-esp32-20241016 (2024-10-16-14:17)
Licensed under GNU GPL v2
For bug reports, read
http://openocd.org/doc/doxygen/bugs.html
DEPRECATED! use 'gdb port', not 'gdb_port'
DEPRECATED! use 'tcl port' not 'tcl_port'
CDRTOSConfigure
Info : Listening on port 50001 for tcl connections
Info : Listening on port 50002 for telnet connections
Error: unable to open ftdi device with description '*', serial '*' at bus location '*'
C:/Users/cfsor/AppData/Local/Arduino15/packages/esp32/tools/openocd-esp32/v0.12.0-esp32-20241016/bin/../share/openocd/scripts/target/esp_common.cfg:9: Error:
at file "C:/Users/cfsor/AppData/Local/Arduino15/packages/esp32/tools/openocd-esp32/v0.12.0-esp32-20241016/bin/../share/openocd/scripts/target/esp_common.cfg", line 9
[2025-02-01T09:32:08.862Z] SERVER CONSOLE DEBUG: onBackendConnect: gdb-server session closed
GDB server session ended. This terminal will be reused, waiting for next session to start.
