Hey Ya’ll,
I’ve created an I2C system for reading a large amount of analog thermisters. Each slave arduino mega reads the voltage of a probe to each of its analog ports. The master then collects the data sequentially from each slave and writes each value to its own column in a csv file on an onboard SD card. However, the master repeats the first value in the place of the second before moving on to the rest of the values in order. (1,1,3,4,5…) I think i’ve isolated the problem to GETREADS(), the function that requests the data:
int numUnits = 5; //Total number of arduinos
int SlaveDeviceId;
int numPin;
long xInit;
void GETREADS(){
for (int i=2; i<=numUnits; i++){ //The master is number 1, so iteration starts at 2
SlaveDeviceId=i;
numPin=2;
Wire.beginTransmission(SlaveDeviceId); Wire.write(numPin); delay(10);
int available = Wire.requestFrom(SlaveDeviceId, (byte)2);
if(available == 2) { xInit = Wire.read() << 8 | Wire.read();} else { Serial.print("ERROR 403: WRONG bytes ARDUINO 2>> "); Serial.println(available); } Wire.endTransmission();
for (int j=(i-2)*16-1; j <= (i-2)*16+16; j++){
if(available == 2) { x[j] = Wire.read() << 8 | Wire.read();
Vo = (x[j]); G2 = G1 * (1023.0 / (float)Vo - 1.0);
x[j]=G2;
} else { Serial.print("ERROR 403: WRONG bytes ARDUINO " + String(SlaveDeviceId) + " >> ");
numPin=numPin+1;
And here is the data for the slaves:
#include <Wire.h>
const byte NODE_ADDRESS = 3;//<----------SLAVE NAME
byte LastMasterCommand = 0;
void setup(){
Wire.begin(NODE_ADDRESS); // Join i2c bus with Slave ID
Wire.onReceive(receiveCommand); // Register talk event
Wire.onRequest(slavesRespond); // Register callback event
void loop(){
// delay(100);
void receiveCommand(int howMany){
LastMasterCommand = Wire.read(); // 1 byte (maximum 256 commands)
void slavesRespond(){
int returnValue = 0;
switch(LastMasterCommand){
case 0: // No new command was received
Wire.write("NA");
case 1: // DEVICE ID
returnValue = NODE_ADDRESS;
case 2: // Return A0 sensor value
returnValue = analogRead(A0);
case 3: // Return A1 sensor value
returnValue = analogRead(A1);
case 4: // Return A2 sensor value
returnValue = analogRead(A2);
case 5: // Return A3 sensor value
returnValue = analogRead(A3);
case 6: // Return A4 sensor value
returnValue = analogRead(A4);
case 7: // Return A5 sensor value
returnValue = analogRead(A5);
case 8: // Return A6 sensor value
returnValue =analogRead(A6);
case 9: // Return A7 sensor value
returnValue = analogRead(A7);
case 10: // Return A8 sensor value
returnValue = analogRead(A8);
case 11: // Return A9 sensor value
returnValue = analogRead(A9);
case 12: // Return A10 sensor value
returnValue = analogRead(A10);
case 13: // Return A11 sensor value
returnValue = analogRead(A11);
case 14: // Return A12 sensor value
returnValue = analogRead(A12);
case 15: // Return A13 sensor value
returnValue =analogRead(A13);
case 16: // Return A14 sensor value
returnValue = analogRead(A14);
case 17: // Return A15 sensor value
returnValue = analogRead(A15);
byte buffer[2]; // Split int value into two bytes buffer
buffer[0] = returnValue >> 8;
buffer[1] = returnValue & 255;
Wire.write(buffer, 2); // Return response to last command
LastMasterCommand = 0; // Null last Master's command
Can anybody see why it’s repeating the first value twice?
