Math Help?
Hi guys. This is my first time using arduino. I am using it on a teensy++. Heres what I am trying to do. I am taking an analog input from a pressure sensor and doing some math to it and eventually displaying it on a LCD.
Problem is I can only get two places past the decimal point. Here is the code so far. I also need to get it to display in notation, so .0001 shows up as 1e-4
Any ideas?
-Jerry
const int numReadings = 10;
int readings[numReadings];      // the readings from the analog input
int index = 0;                  // the index of the current reading
int total = 0;                  // the running total
int average = 0;                // the average
int inputPin = 0;
float torr = .0075;
float pa;
float volts;
float pressure;
float offset;
  // initialize serial communication with computer:
  // initialize all the readings to 0:
  for (int thisReading = 0; thisReading < numReadings; thisReading++)
    readings[thisReading] = 0;
  // subtract the last reading:
  total= total - readings[index];
  // read from the sensor:
  readings[index] = analogRead(inputPin);
  // add the reading to the total:
  total= total + readings[index];
  // advance to the next position in the array:
  index = index + 1;
  // if we're at the end of the array...
  if (index >= numReadings)
    // ...wrap around to the beginning:
    index = 0;
  // calculate the average:
  average = total / numReadings;
  float volts = average * .0097;
  float offset = volts - 8.5000;
  float pa = pow(10.0000, offset);
  // send it to the computer (as ASCII digits)
  Serial.println(offset);
  Serial.println(pa);
  delay(100);
Jerry,
You do know that you can do this:
float x;
x=1.2345;
Serial.println(x, 4);
and get this:
1.2345
I don't know of a way, short of writing your own, to get exponential
format for numeric output. I have tried sprintf() with a "%e" format
but that did not produce usable output.
Thanks. Didnt work.
Ended up doing it the hard way.
Here's the final-ish code. I am probably going to add some setpoints to prevent certain valves from opening at high pressures.
-Jerry
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 10, 0, 1, 2, 3, 4, 5, 6, 7);
int inputPin = 0;
int exponent;
float torr = .0075;
float pa;
float volts;
float pressure;
float offset;
  lcd.begin(20, 4);
  lcd.clear();
  lcd.setCursor(1, 0);
  // Print a message to the LCD.
  lcd.print("Turbopump Pressure");
  index = index + 1;
    index = 0;
  if (volts <= 8.5 && volts > 7.62) {
    exponent = -3;
    offset = volts - 7.62;
  if (volts <= 7.62 && volts > 6.62) {
    exponent = -4;
    offset = volts - 6.62;
  if (volts <= 6.62 && volts > 5.62) {
    exponent = -5;
    offset = volts - 5.62;
  if (volts <= 5.62 && volts > 4.62) {
    exponent = -6;
    offset = volts - 4.62;
  if (volts <= 4.62 && volts > 3.62) {
    exponent = -7;
    offset = volts - 3.62;
  if (volts <= 3.62 && volts > 2.62) {
    exponent = -8;
    offset = volts - 2.62;
  if (volts <= 2.62 && volts > 1.8) {
    exponent = -9;
    offset = volts - 1.62;
  float torr = pow(10, offset);
  Serial.println(exponent);
  Serial.println(volts);
  Serial.println(torr);
  lcd.setCursor(5, 1);
  lcd.print("e   Torr");
  lcd.setCursor(1, 1);
  lcd.print(torr);
  lcd.setCursor(6, 1);
  lcd.print(exponent);
    if (volts > 8.5) {
    lcd.setCursor(1, 2);
    lcd.print("Overrange     ");
    if (volts < 1.8 && volts > 0.5) {
    lcd.print("Underrange     ");
    if (volts < 0.5) {
    lcd.print("Sensor Error   ");
    if (volts >= 1.8 && volts <= 8.5) {
      lcd.setCursor(0, 2);
  lcd.print("                ");
  delay(50);
