Math problem I think with UL and millis()
Hello all, I read on the internet that math with millis() need to put UL when doing calculation, that what I tried to use in my code.
So each time ร  run the code (arduino UNO), the number 1 is automaticaly put inside the tpsInsolation UL variable. So, my program is ended after 1 second only, instead of 60 000 ms (variable declaration at the beginning of the code)
Curiosly, when, In the loop(), I replace tpsInsolation by for exemple 10 000, the program works...
Need help please because I tried many things without result...
/*pin assignรฉ
  Relai : 2
  bouton vert 3:
  bouton rouge 4:
  buzzer : 5
  LCD : I2C
#include <Arduino.h>
#include <Wire.h> //pour la communication I2C (SD, ATH20,LCD)
#include "OneButton.h" // bibliotheque qui gรจre l'รฉvenement des buttons
#include "rgb_lcd.h"
rgb_lcd lcd; // pour le LCD
const char symboleE = B11011111;//symbole รฉ
const byte relai = 2;
const byte buzzer = 5;
// Setup a new OneButton on pin A1.
OneButton bpVert(4, true);
// Setup a new OneButton on pin A2.
OneButton bpRouge(3, true);
unsigned long tpsIncrementation = 1UL * 60000; // en millisecondes pour l'incrementation du tps d'insolation, mn/mn
unsigned long tpsIncrementation2 = 5UL * 60000; // pour incrementation avec bouton stop
unsigned long tpsInsolation = 1UL*60000; //en millisecondes, initialisรฉ ร  1mn
unsigned long tpsInsolationMax = 60UL*60000; // 1h d'insolation
unsigned long tpsEcoule = 0;
unsigned long dcy = 0;
bool cycleEnCours = false;
bool finDeCycle = false ;
bool validationFinDeCycle = false;
//ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง
//ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง SETUP ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง
  while (!Serial) {};// attente du demarrage port serie
  lcd.begin(16, 2);// initialisation nb libre et colonne du lcd
  lcd.clear();
  delay(50);
  pinMode(relai, OUTPUT);
  digitalWrite(relai, LOW);
  delay(50);
  pinMode(buzzer, OUTPUT);
  delay(50);
  bpVert.attachClick(incrementation); // lancement de la fonction
  bpVert.attachLongPressStart(dcyInsolation); //lancement de la fonction insolation
  bpRouge.attachClick(arretInsolation);
}// fin de la fonction setup
//ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง LOOP ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง
  // keep watching the push buttons:
  bpVert.tick();
  bpRouge.tick();
  //delay(10);
    if (cycleEnCours == true){
        tpsEcoule = 1UL*(millis()-dcy);
          if(tpsEcoule > tpsInsolation) {
            //cycleEnCours = false;
            arretInsolation();
affichageLcd();
/*Serial.print("Cycle en cours:");
Serial.println(cycleEnCours);
Serial.print("tpsEcoule:");
Serial.println(tpsEcoule/1000);
Serial.print("tpsInsolation = ");
Serial.println(tpsInsolation);
//Serial.print("Millis:");
//Serial.println(millis());
//Serial.print("tpsInsolation + millis = ");
//unsigned long tps = millis() + tpsInsolation;
//Serial.println(tps);
Serial.print("dcy:");
Serial.println(dcy);
delay(2000);*/
}// fin du loop
//ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง DCY INSOLATION ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง
void dcyInsolation()
    if(tpsInsolation =! 0 && cycleEnCours == false) {
      digitalWrite(relai,HIGH);
      dcy = millis();
      lcd.clear();
      buzzerDcy();
      cycleEnCours = true;
//ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง ARRET INSOLATION ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง
void arretInsolation() {
  if(cycleEnCours == true) {
    digitalWrite(relai,LOW);
    buzzerFin();
    finDeCycle = true;
  else{
  tpsInsolation = 1UL*(tpsInsolation + tpsIncrementation2); // incrementation de 5mn/5mn si on est en dehors d'un cycle
if (tpsInsolation > tpsInsolationMax) tpsInsolation = 60000;
  /*Serial.println(tpsIncrementation);
  Serial.print(tpsInsolation/60000);
  Serial.println("mn");
  Serial.println();*/
}// fin de la fonction DHT
//ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง INCREMENTATION ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง
void incrementation(){
if (cycleEnCours == false) {
  tpsInsolation = 1UL*(tpsInsolation+tpsIncrementation); // incrementation de la variable "incrementation"
      if (finDeCycle == true) finDeCycle = false;
//ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง LCD ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง
void affichageLcd()
  //static bool changementEtatCycle = false;
  static unsigned long tpsInsolationLcdMn = 0;
  static unsigned long tpsRestantLcdS = 0;
  tpsInsolationLcdMn = 1UL*(tpsInsolation/60000);
  tpsRestantLcdS = 1UL*((tpsInsolation-tpsEcoule)/1000);
      if (cycleEnCours==false && finDeCycle == false) {
      lcd.clear();
      lcd.setCursor(0, 0);
      lcd.print("Tps insolation:");//5 char
      lcd.setCursor(1, 1);
      lcd.print(" ");//
      lcd.setCursor(0, 1);
      lcd.print(tpsInsolationLcdMn);//
      lcd.setCursor(3, 1);
      lcd.print("mn   (max 60)");//
      if (cycleEnCours==true){
      lcd.clear();
      lcd.print("Cycle en cours...");//5 char
      lcd.print("Reste :");//
      lcd.setCursor(8, 1);
      lcd.print("   ");//
      lcd.setCursor(7, 1);
      lcd.print(tpsRestantLcdS);//
      lcd.setCursor(12, 1);
      lcd.print("s");//
    if (finDeCycle == true){
      lcd.clear();
      lcd.print("Insolation");
      lcd.print("fini !");
//ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง BUZZER DCY ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง
void buzzerDcy()
  for(int i = 0 ; i<3; i++){
  tone (buzzer, 1100);
  noTone(buzzer);
  delay(200);
//ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง BUZZER FIN ยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยงยง
void buzzerFin()
  delay(2000);
  noTone(buzzer);
In setup(), serial.Print() the initial values you have asked to be set into each of these variables. Are they what you expected?
Il y a une erreur sur cette ligne :
Tu assignes 1 ร  la variable car !0 = 1
Genial, merci beaucoup, j'ai utilisรฉ une syntaxe dont j'ignorai l'existence ^^
tout est rentrรฉ dans l'ordre avec la bonne syntaxe de comparaison
