I have a small probably very simple problem I cant figure out. I do some math in my if statements below, but there is some problem with it. Among others I get the following error message "warning: invalid conversion from 'long unsigned int (*)()' to 'long int' [-fpermissive]
StartMillis = millis;
Best regards
Rasmus
#include "MegunoLink.h" // Helpful functions for communicating with MegunoLink.
#include <Wire.h>
// Interval (milliseconds) between sending analog data
const unsigned SendInterval = 20; // [ms]
// The plot we are sending data to.
TimePlot MyPlot;
// constants won't change. Used here to set pin numbers:
int ControlPin = 6; // LED connected to digital pin 9
int buttonPin = 12; // The number of the pin controlled by the button
// Variables will change:
int val = 25; // variable to store the value calculated based on time passed since the test was started.
long StartMillis = 0; // Millis value when test was started.
int Flag = 0; // flag to mark if the test should be ongoing
Wire.begin();
pinMode(ControlPin, OUTPUT); // sets the pin as output
pinMode(buttonPin, INPUT); // sets the pin as input
if (digitalRead(buttonPin) == LOW) {
Serial.println( "New test initiated");
Flag = 1;
if (Flag == 1) {
val = floor(((millis - StartMillis) / 500) + 25); // Calculate val based on time elapsed
analogWrite(ControlPin, val); // AnalogWrite values from 0 to 255
if ((millis - StartMillis) > 60000) {
Flag = 0;
delay (5000);
val = 25;
Please follow the advice given in the link below when posting code. Use code tags (the </> icon above the compose window) to make it easier to read and copy for examination
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
C:\Users\rafb\AppData\Local\Temp\untitled145637832.tmp\sketch_sep15a\sketch_sep15a.ino: In function 'void loop()':
C:\Users\rafb\AppData\Local\Temp\untitled145637832.tmp\sketch_sep15a\sketch_sep15a.ino:32:21: warning: invalid conversion from 'long unsigned int (*)()' to 'long int' [-fpermissive]
C:\Users\rafb\AppData\Local\Temp\untitled145637832.tmp\sketch_sep15a\sketch_sep15a.ino:36:28: warning: pointer to a function used in arithmetic [-Wpointer-arith]
sketch_sep15a:36:43: error: invalid operands of types 'long unsigned int (*)()' and 'int' to binary 'operator/'
C:\Users\rafb\AppData\Local\Temp\untitled145637832.tmp\sketch_sep15a\sketch_sep15a.ino:40:13: warning: pointer to a function used in arithmetic [-Wpointer-arith]
C:\Users\rafb\AppData\Local\Temp\untitled145637832.tmp\sketch_sep15a\sketch_sep15a.ino:40:30: warning: ISO C++ forbids comparison between pointer and integer [-fpermissive]
exit status 1
option enabled in File -> Preferences.
