I have a math problem (pun not intended) on an Arduino Mega.
I am running this code:
float dA = (mx + 255) / 510;
float dB = (mX + 255) * (1/510);
with mX
being a value between -255
and 255
. The output on dA
should be at 0
when mX
is at 255
, be at 1
when mX
is -255
, and anywhere in between is mapped. Same thing for dA
, but the output is the opposite. However, the outcome is always 0
for both.
Full Code
// Motor A connections
int enA = 9;
int in1 = 8;
int in2 = 7;
// Motor B connections
int enB = 3;
int in3 = 5;
int in4 = 4;
int xPin = A0;
int yPin = A1;
int swPin = 2;
// Set all the motor control pins to outputs
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode(xPin, INPUT);
pinMode(yPin, INPUT);
pinMode(swPin, INPUT_PULLUP);
// Turn off motors - Initial state
digitalWrite(in1, LOW);
digitalWrite(in2, LOW);
digitalWrite(in3, LOW);
digitalWrite(in4, LOW);
analogWrite(enA, 0);
analogWrite(enB, 0);
int X = analogRead(xPin);
int Y = analogRead(yPin);
boolean sw = !digitalRead(swPin);
int mX = map(X, 0, 1024, -255, 255);
int mY = map(Y, 0, 1024, -255, 255);
int mA = mY;
int mB = mY;
// EVIL CODE
float dA = (mX + 255) / 510;
Serial.print("mX: ");
Serial.print(mX);
Serial.print(", mY: ");
Serial.print(mY);
Serial.print(", dA: ");
Serial.print(dA);
Serial.print(", dB: ");
Serial.println(dB);
void speedA(int a) {
if (a > 0) {
digitalWrite(in1, HIGH);
analogWrite(enA, a);
} else if (a < 0) {
digitalWrite(in2, HIGH);
analogWrite(enA, a * -1);
void speedB(int b) {
if (b > 0) {
digitalWrite(in3, HIGH);
analogWrite(enB, b);
} else if (b < 0) {
digitalWrite(in4, HIGH);
analogWrite(enB, b * -1);
Thanks in advance!
