hi everyone!
how can i convert a result as example below in one formula? and i need the result show up on a 4digit 7 segment display.
1 * 0.95 = 95 instead of 0.95
2 * 0.95 = 19 instead of 1.9
99 * 0.95 = 9405 instead of 94.05
Thank you
hi everyone!
Thank you
Are you sure you don't want 95, 190, and 9405? That would make more sense.
1 * 95 = 95
2 * 95 = 190
99 * 95 = 9405
hi john
it is clever!
but i don't want the result last digit 0.
any way to exlude it in the result.
i could put a if statement to determine is there any 0 in last digit. but how can i do it?
i got it.
first use modular
number % 2
if result is 1 equal to singular
if result is 0 equal to plural
if the number is singular just multiple by 95 like this one below
1*95 = 95
on the other side if the number is plural the result will be
2 * 95 = 180
12 * 95 =1140
A stupid question ! please tell me !
7% 2 = 1
95 % 2 = 1
are they right?
Thank you
are they right?
Yes, but you could have written a sketch to confirm that in less time than it took to post the question.
Looks like the expression you want is:
int result = (X & 1) ? X95 : (X95)/10;
This will produce the results:
0 -> 0
1 -> 95
2 -> 19
3 -> 285
4 -> 38
5 -> 475
97 -> 9215
98 -> 931
99 -> 9405
Thanks John for the hint. I did it yesterday.
My code is longer but it works. but i would like to know how the way you do it.
would you please explain your expression? it is quiet confuse for me.
int number = random (1,99);
if (number % 10 == 0){
goto random_number; <----- I try to not using goto(); function but i am not clever enough to not using it.
if (number % 2 == 0 ){
answer = number * 95 / 10;
if ( number % 2 == 1){
answer = number * 95;
PaulS:
are they right?
ok. Paul! no more stupid question next time. thanks for remind me that solving problem by myself will make me clever than asking.
tonify:
To get rid of the goto, try:
int number;
do {number = random (1,99);} while (number % 10 == 0) ; // oops... had != before
answer = (number * 95) / 10;
The formula "int result = (X & 1) ? X95 : (X95)/10;" is just a shorthand way of saying:
int result;
if (X & 1) // This is the same as: (X % 2) != 0
result = X * 95;
result = (X * 95) / 10;
thanks john !
