Hello,
I have an energy meter which stores the energy index in 4 registers modulo 10000 per register.
I am reading them with modbus protocol. i want the reading to be in kw thats why i divide by 1000.
So first time i tried like this.
unsigned long c_activ = node.getResponseBuffer(3) * 1000000 + node.getResponseBuffer(2) * 100000 + node.getResponseBuffer(1) * 10 + node.getResponseBuffer(0) / 1000;
.. and the reading was wrong. (if i remeber corectly sometimes was correct but most times was wrong).
Then i tried like this.
unsigned long n3 = 1000000;
unsigned long n2 = 100000;
unsigned long n1 = 10;
unsigned long n0 = 1000;
unsigned long c_activ = node.getResponseBuffer(3) * n3 + node.getResponseBuffer(2) * n2 + node.getResponseBuffer(1) * n1 + node.getResponseBuffer(0) / n0;
.. and the readings was always correct, and i only changed the numbers with variables that contains the same numbers.
Can anyone think of a reason why it dosnt work directly with numbers?
I want to get rid of the variables to save memory.. Thank you.
