jremington:
For tilt measurements, the calculations done in the code you posted are incorrect.
For example, the following makes no sense at all.
int xAng = map(AcX,minVal,maxVal,-90,90);
int yAng = map(AcY,minVal,maxVal,-90,90);
int zAng = map(AcZ,minVal,maxVal,-90,90);
sketch come from http://www.instructables.com/id/How-to-Measure-Angle-With-MPU-6050GY-521/
Power_Broker:
I think this is what you're looking for.
If you want example code, below is a sketch I use for laser altimeter stabilization on one of my RC airplanes and works correctly (except that I'm using an MPU9250 instead):
#include <Wire.h>
#include <FaBo9Axis_MPU9250.h>
#include <Servo.h>
#define M_PI 3.14159265359
FaBo9Axis fabo_9axis;
float offsetax = 0;
float offsetay = 0;
float ax, ay, az;
float gx, gy, gz;
float integrated_gx = 0;
float scaled_gx = 0;
float integrated_gy = 0;
float scaled_gy = 0;
float angleRoll = 0;
float anglePitch = 0;
float A_ = 0.7;
float dt = 0.01;
float angleRollAcc = 0;
float anglePitchAcc = 0;
byte gyroSensitivity = 131; //16 bit ADC with +-250dps --> sensitivity = 2^16 / 500 = 131
double currentTime = millis();
double timeBench = currentTime;
double samplePeriod = 10; //sample period in ms
Servo horizontal;
Servo vertical;
if (fabo_9axis.begin())
Serial.println("configured FaBo 9Axis I2C Brick");
Serial.println("device error");
while (1);
horizontal.attach(30);
vertical.attach(31);
horizontal.write(90);
vertical.write(90);
//prime the timer
//execute once per sample time-period
if ((currentTime - timeBench) >= samplePeriod)
//reset timer
//get data
fabo_9axis.readAccelXYZ(&ax, &ay, &az);
fabo_9axis.readGyroXYZ(&gx, &gy, &gz);
//remove offset
ax = ax - offsetax;
ay = ay - offsetay;
//scale by sensitivity
scaled_gx = gx / gyroSensitivity;
scaled_gx = gy / gyroSensitivity;
//integrate gyro readings
integrated_gx = scaled_gx * dt;
angleRollAcc = -atan2(ax, sqrt((ay * ay) + (az * az))) * 180 / M_PI;
anglePitchAcc = atan2(ay, sqrt((ax * ax) + (az * az))) * 180 / M_PI;
angleRoll = A_ * (angleRoll + integrated_gx) + (1 - A_) * (angleRollAcc);
anglePitch = A_ * (anglePitch + integrated_gx) + (1 - A_) * (anglePitchAcc);
//print for debugging////
Serial.print("angleRoll: ");
Serial.print(angleRoll);
Serial.print(" anglePitch: ");
Serial.print(anglePitch);
/*Serial.print("angleRoll: ");
Serial.print((byte)map(angleRoll,-90,90,0,180));
Serial.println((byte)map(anglePitch,-90,90,180,0));*/
horizontal.write(map(angleRoll, -90, 90, 0, 180));
vertical.write(map(anglePitch, -90, 90, 0, 180));
Thank you for your sketch.
I will try to adapt it to MPU-6050 / GY-521.
If you unclude wire.h, do you need #define M_PI 3.14159265359 ?
jremington:
What are you trying do?
with raw data from MPU-6050 / GY-521 I want display on my tft screen something like that :
